Old 14-Mar-2005, 22:06   #1
wosser wosser is offline
Real wheel rubbing
Evening all
Ive just fitted a talon rear carrier and changed the gearing to 14/38, the problem is the rear is now rubbing the rear guard 94 links in the chain the bike 996SPS
any help appreciated
Wosser
Old 14-Mar-2005, 22:10   #2
Did you buy a longer chain as well? Dont know what standard gearing is on your bike but you adjust the chain tension by moving the wheel on an eccentric adjuster which will alter the effective height of the wheel and bring it closer to the hugger. You need a longer chain or a smaller tyre or rotate the adjuster through 180 degrees but this might mess up your steering as well.
Old 14-Mar-2005, 23:22   #3
Thanks rockhopper all sorted
Wosser
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:30.
