Old 30-Mar-2005, 19:12   #1
keefer keefer is offline
keefer's Avatar
different crank case breather ?
I have just got myself a carbon under seat crank case breather expansion box (what a mouthful)
now this does away with the usual plastic item that sits behind the top cylinder, and I have had a look at some pictures of race bikes. And what im wandering is do I need to have a different crank case breather to attach the hose to ?
any racers out there who have had this part please let me know. cheers. K
Old 30-Mar-2005, 19:43   #2
neil748r neil748r is offline
Yes, you'll need a new breather tower, hoses and a reed valve for the airbox.
Be warned, you'll probably pay more for the other items you need than you did for the breather box itself!
Part numbers:
Crankcase breather tower - 257.2.003.1A
Hose (tower to breather box) - 876.1.064.2A
Hose (breather box to airbox) - 876.1.057.1A
Airbox reed valve - 593.1.019.2A
Hope that helps!
Neil.
P.S. STM and Vee-Two (Australia) both do Corse style breather towers that are significantly cheaper than the genuine Corse item.
P.P.S. If you need any other info just drop me a line.
[Edited on 30-3-2005 by neil748r]
Old 30-Mar-2005, 19:56   #3
keefer's Avatar
Nice one
should have the hose with it
will have to wait and see when it turns up.
will give you a bell and pick your brains when its in front of me if that's ok.
thanks again. K
Old 30-Mar-2005, 19:58   #4
No problem mate.
See attached, you'll get a better idea of how it all plumbs together.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:31.
