Old 01-Apr-2005, 14:34   #1
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
R model ECU rev limiter
Hi Folks (again),
Well the Spring makeover is complete, and I've finally got the S/R cams installed in my 998.
The cams are part of the DP upgrade kit of 45/50mm pipes, S/R cams and 996R ECU, which are all now installed.
Now the odd thing is this:
The standard strada ECU has a rev limit of 10,000ish.
I ran my bike with 45mm open Termis with the supplied ECU, which gave a rev limit of about 11,200. This high limit was useful at the track. I also ran this ECU with the 45/50mm kit.
The new 996R ECU seems to give a rev limit of about 10,500.
I'm not too upset to loose the higher limit, I guess it may lead to a little improved engine life. But I'm confused as I would have expected the 996R to have a high rev limit.
Also, this morning I've read an old PB test of the 998S (against RSV-R and SP2) and they refer to the 998S having a rev limit of 11,000.
Therefore, the questions are:
1. What is the standard rev limiter on a 996R?
2. Same as above, but for 998S?
3. Is it possible to adjust or change the rev limit?
4. Why on earth do I want the high rev limit? Am I being silly?
Yours,
The (not so) Very Rev Spinoli
PS: To anyone who has also read my query on the wheels - I've been a bad, bad boy. No more pocket money.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:31.
