  #21
Old 03-Nov-2010, 20:47
Originally Posted by Col996s
On the speedo drive side there is a loose ring which engages with the speedo drive. How does this come out before I remove the bearings?
With a good pull?
  #22
Old 06-Nov-2010, 17:55
Col996s's Avatar
Col996s Col996s is offline
Bikes: 996S
Bearings out, wheels with powder coaters. I have to admit that I let a garage remove the bearings as I was struggling.
I have been looking at the bearings that were removed and they look and feel fine so not going to bother to replace.
  #23
Old 06-Nov-2010, 22:21
Trig's Avatar
Trig Trig is offline
Bikes: Ducati 999, BSA A65 Lightning, Matchless G80s
Mood: Fed up with DIY!
Colin - did you tell him you wanted to reuse the bearings? Been a while since I changed mine but if he knocked them out by hitting the inner races they are probably ruined.
  #24
Old 06-Nov-2010, 23:02
Col996s's Avatar
Bikes: 996S
Glenn,
He used a press to get them out. There are no signs of any damage and they rotate smoothly with no play.
  #25
Old 07-Nov-2010, 00:58
Trig's Avatar
Depends where he made contact. You might not be able to feel the damge. Might be worth just checking that he pressed them out via the outer race.
  #26
Old 07-Nov-2010, 09:25
YMFB's Avatar
YMFB YMFB is offline
for me I wouldnt re-use the wheel bearings on a sports bike and I would buy them from a bearing stockist not a m/c shop. I tell them what the application is and the bearing ref which is usually etched in the outer race face.
I get mine from http://www.ashleypower.co.uk/ but thats only because we use them at work and they deliver to the office.
Yesterday at the dirt bike show at Stoneleigh Park I saw a company specialising in sprucing up wheels http://www.central-wheel.co.uk/ I know they are only going to exhibit their best products but they looked fantastic.
  #27
Old 17-Nov-2010, 20:02
Col996s's Avatar
Bikes: 996S
NEW bearings fitted to the front wheel. I used the bearings in the freezer trick and I have to say they went in with very little effort.
I was not happy with the standard of the paint finish on the rear wheel and the powder coaters have agreed to strip it and re-paint it and I pick it up next Saturday.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:35.
