  #21
Old 31-May-2005, 17:08
khu996's Avatar
khu996 khu996 is offline
Originally posted by Dseered
Mine has developed a shudder recently, we got the front wheel up today and think we have found the problem, left fork 2 rings showing, right leg 3 rings showing, eeeek, how can that happen ??
That is unbelievable! WTF!!!
With the original problems you had with the bike possibly being 03MY and now this? Your dealer has rather a lot to answer for...
  #22
Old 31-May-2005, 17:18
Surely the wheel will be slightly at an angle, which would mean it should be easier to turn into either a left or right turn, and harder to turn the opposite way?
  #23
Old 31-May-2005, 17:33
Now I'm trying to work out the physics of counter steering and wheel alignment, my head hurts! Saying that I am the same as you in preferring left handers, Andy Ibbot told me that this is probably due to the UK roads and being cambered.
  #24
Old 31-May-2005, 18:21
Gizmo Gizmo is offline
Mood: is it the weekend yet??
it makes no difference to wheel/axle or ride - the springs compensate one being compressed by a bit more than the other, it'll only make a difference at full compression where one bump stop works first or full extension where one tops out before other. Needs levelling up and checking out though.
Sorted a ride height gauge for rear now DCR, can drop your rear adjustor rod out, clean, set-up and refit in no time.
  #25
Old 31-May-2005, 18:25
Gizmo, you're right obviously, I was thinking along the lines of static forks, obviously one leg will be extended/compressed more than the other.... d'oh!
I guess it will only make a difference under hard braking and bottoming out etc
  #26
Old 31-May-2005, 18:45
it'l alter preload slightly as one leg is compressed more, but as we've yet to check the preload adjustors they might be out as well..........
  #27
Old 31-May-2005, 22:35
Ducnow Ducnow is offline
Its gonna be like a new bike all over again
Hahahahahahaha, yeah i though about that.
I was like....... "Dseered must have felt he had a new and much better handling bike after he fixed that"
Good for you
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:02.
