Ducati Sporting Club
Home Calendar Gallery Membership Online Shop DSC Blogs Extras
Go Back   Ducati Sporting Club > Model Specific - Discussion, Technical Problems and Help > General - Motorcycle only
Reload this Page Is a Radial master NEEDED to get the best from radial calipers?
Forum Home Register FAQ Search Forum Recent Posts Mark Forums Read
General - Motorcycle only Motorcycle Tech only please.
  #11
Old 23-Mar-2013, 04:52 PM
Originally Posted by batesy2
Im in the Piemans camp here, Less brake--More gas. we dont need silly brakes,just means we have to be savage on the gas out of corners cos we slowed down to much
See what this season brings. might have to eat my words -)
Good luck at the Hairpins then
Frank is upgrading his road bike brakes I believe.
  #12
Old 24-Mar-2013, 08:05 AM
DSC Member Iconic944ss Iconic944ss is offline
DSC Webteam
Bikes: 1993 - 944ss / Aprilia Falco / ST4S
Yes, indeed - this one, perhaps
... The Falco Feasant Fryer
Cheers - Frank
  #13
Old 27-Mar-2013, 10:38 AM
Pablo Pirate Pablo Pirate is offline
Mood: Like the English weather happy go free Beep! Beep!
Howdo!
I fitted a set of 848 forks and radial 4 pad calipers to my Superlight and a Brembo radial M/C.................. The bike has V strong progressive braking, couldn't ask for more. Works in town as well as from 160+ (Closed road don't want to upset the fun police).
M/C is definitly the way to go to get the best from the brakes. Me GSXR is a cracking bike apart from the brakes, as soon as I've sold me other kidney it's on the shopping list!
Cheers Pablo
  #14
Old 27-Mar-2013, 06:18 PM
Frank,
The Supersport (and 748, Chris) brake master cylinder is 16mm and is not a good hydraulic ratio match to the Brembo 4 pad calipers. The 749/999 radial master cylinder is 18mm and would be a good choice— any 18mm actually.
Radial pumps actually don't offer better stopping power, so a conventional 18mm unit will also work well.
  #15
Old 27-Mar-2013, 06:43 PM
Originally Posted by Pablo Pirate
Howdo!
Cheers Pablo
Thats interesting, I have a set of 848 forks and yoke I'm selling. Was it much work to change?
  #16
Old 27-Mar-2013, 08:26 PM
Originally Posted by Shazaam!
Frank,
Yep, found that out, that is why I converted a set of 749/999 radial master cylindrs to use with the P4 calipers I fitted to my 748, as per the thread that I posted a few years ago about the conversion that Ant kindly relocated for me fter I failed to find it .
BTW, if the 749/999 is a ratio of 18mm, what is the ratio of the latest 1098/1199/Penigale master cylinders?
  #17
Old 27-Mar-2013, 08:56 PM
DSC Webteam
Frank,
Thanks Larry,
A matching radial master from the same bike arrived today although it needs a little work. Looks like I need to get a pressure operated switch for the brake light switch to work. Fingers crossed its an 18mm.
Cheers - Frank
  #18
Old 27-Mar-2013, 09:14 PM
18mm diameter (same as the 749/999), with a 19mm piston-fulcrum distance (don't remember what the 749/999 distance is).
  #19
Old 27-Mar-2013, 09:20 PM
Thanks Larry, will try and find out what the 749/999 piston -fulcrum is.
  #20
Old 27-Mar-2013, 10:03 PM
Initially had a set of Monster S4r forks but found out there where damaged, this led to the 848 forks. Main issue was the lack of alloy on the top yoke (Bottom would have to be shimmed) So Mick at Pro-Mach made some adjustable yokes for the bike, also had to knock up some shims to fit the front wheel after converting the speedo drive to the rear wheel.
Cheers Pablo
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2018, Jelsoft Enterprises Ltd. - © Ducati Sporting Club - All times are GMT +1. The time now is 07:11 AM.
