Old 14-Aug-2005, 18:43   #1
the phantom pieman the phantom pieman is offline
the phantom pieman's Avatar
Mood: Sort of shuffling along .....
head angle ...
For road use , does changing to the steeper head angle make any difference ? ( quicker steering , i hope , but is that a good thing for every day , or not?)
And if it is worth doing , is it easy to do, or best left to the pros?
Old 14-Aug-2005, 19:10   #2
keefer keefer is offline
keefer's Avatar
not worth doing in my opinion.
if you look on any race ducati's you wont see it done. ok because they have a longer swing arm.
if you want quicker steering best off raising the ride height
Old 14-Aug-2005, 20:38   #3
No real harm in doing it, you may not notice too much difference on the road though (unless you're a road speed freak!!! ) and you will lose the steering lock.
What are you trying to gain by doing it? If its for quicker steering, you could try jacking the back up a touch - it does create a similar effect on the steering and can be easily tweaked (more variance) or put back to original rather than moving the steering head.
Tim
[Edited on 14-8-2005 by Rattler]
Old 14-Aug-2005, 22:48   #4
Thanks,
I have jacked up the back end ... just wondering if there was a trick I was missing !
I thought it might have more relavence on the track
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:49.
