Old 09-Feb-2006, 19:29   #1
cj2 cj2 is offline
Bikes: Multistrada 1200s DAir
14T sprocket ST4S ?
Has anyone fitted a 14T sprocket (ST4S '03) - i've done this based on items i've read here and other sites, the problem is that i get a sort of 'droning' noise when coasting (clutch-in, tickover) which comes in at about 30mph as the speed drops but disappears below about 20mph.
I've tried alternate chain tension etc. etc. but can't get rid of it. obviously i've re-fitted the 15T standard and it's then o.k. - is this perhaps the chain rubbing on the plastic guide on top of the swing arm since with the 14T the radius is smaller so brings the chain nearer the swing arm (i'm assumming this 'cos in the condition described, the top of the chain is the slack side).
Any help / suggestions greatly appreciated.
CJ2
Old 09-Feb-2006, 19:42   #2
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
I did this on mine when it had a standard 38 tooth rear on and liked it but
I also had the droning and didn't like that bit.
As I was due a new chain & sprockets anyway I changed over to ST4 gearing - 15/43......
Now that is fun.....
Still geared for about 162 mph at the rev limiter but if you want to it'll lift the front wheel now with ease and is awesome out of the bends....
Old 10-Feb-2006, 01:54   #3
BDG BDG is offline
BDG's Avatar
I did about 19,000 miles with the same 14 tooth front sprocket on, very slight noise but no problem.
I did intend doing what RUshjob did when the chain needed replacing, but sold it.
Old 10-Feb-2006, 10:02   #4
Athelstan's Avatar
Strange This:
I had a 14T front fitted and kept to the std rear ST4s sprocket size plus new chain and have no "droning" noise. There is also no appreciable extra wear on the top swinging arm rubber guide, and no wear of the front sprocket grey plastic cover. So I wonder what is going on cj2?
Old 10-Feb-2006, 10:33   #5
My St2 used to make a droning noise when the chain was too tight.
Old 10-Feb-2006, 21:28   #6
Rushjob's Avatar
Mood: :-)
I think part of the cause as well as the sprocket was the high ride height I have set on mine.......
Old 13-Feb-2006, 09:57   #7
cj2 cj2 is offline
Thanks everyone for the info - i still can't get to the bottom of this so i'm reverting to the 15T with 40T rear and new chain - better to be safe than sorry (i did like the acceleration though with the 14/40 combination that i also tried)
CJ2
Old 13-Feb-2006, 11:33   #8
I hope you'll only be riding like that when you're "familiarising yourself with the performance of your machine"
Old 13-Feb-2006, 12:01   #9
Rushjob's Avatar
Mood: :-)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:19.
