Old 24-Feb-2006, 00:22   #1
swapping pump and tank
any tips to ensure fuel pump fitted correctly and no probelms with o ring?
cheers
Old 24-Feb-2006, 00:33   #2
Make sure tank surface is clean, I usually use a bit of scotchbrite and then I coat the O-ring in Vacuum grease which is a lot like petroleum jelly
Old 24-Feb-2006, 08:46   #3
weeksy2 weeksy2 is offline
Yup, i use vaseline.
The trick is to use 3 bolts of the same thread as the holes and screw in the bolts 1/4 of a turn at a time in a clockwise direction.... This should ensure it doesn't snag anywhere.
Old 24-Feb-2006, 11:28   #4
I'd go with the above, but always ALWAYS have a spare o-ring just in case, they're only something like £7 plus they do stretch over time so there's only a number of times befor eyou'll end up snagging it anyway. It does take some force getting the thing back in also.
Old 24-Feb-2006, 20:45   #5
cheers guys, been into m/rapido today and martin gave me a blow by blow (!!) expalnation, seems I was mis-understanding where the o ring was so no mistakes this time!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:06.
