Model Specific - Discussion, Technical Problems and Help
998 / 996 / 916 / 748
> Brembo pad removal.
Brembo pad removal.
01-Apr-2006, 18:20
i porter
Brembo pad removal.
Hello again thicko here. Can someone explain how to remove the 4 pads from the brembo front calliper.
I see the clip and a pin that goes through. Is it just the case of removing the pin and the clip then the pads will come out.
Or have I to do something else. Thankyou.
i porter
Send a personal message to i porter
Find More Posts by i porter
01-Apr-2006, 18:55
Chrisiball
: Come on spring!!!
pads
Push the wire clip in and pull the pin that slide thru from the side out! Might need pliers to pull it out!
Chrisiball
Send a personal message to Chrisiball
Find More Posts by Chrisiball
01-Apr-2006, 19:03
i porter
Thanks Chris Ill have a go.
i porter
02-Apr-2006, 11:41
4
raykay748R
: 748R, ZXR 400
: Glad to be back down south.
Don't forget a wiggle side to side to push piston back a little in order to pull out the pad, by that I mean the pad wiggles, not you!!!!!
raykay748R
Send a personal message to raykay748R
Find More Posts by raykay748R
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:05.
