Ducati Sporting Club
Home Calendar Gallery Membership Online Shop DSC Blogs Extras
Go Back   Ducati Sporting Club > Model Specific - Discussion, Technical Problems and Help > 998 / 996 / 916 / 748
Reload this Page Lower Timing Belt Cover Removal
Forum Home Register FAQ Search Forum Recent Posts Mark Forums Read
Old 07-Mar-2014, 09:25 PM
r15suk's Avatar
DSC Member r15suk r15suk is offline
I'm trying to remove the lower timing belt cover on my 996 (engine still in the frame) and even when I move all the wiring loom and connectors etc out of the way the best i can, i still cant seem to wiggle the timing cover off and out.
Looking at the situation, it seems that the offending item is the oil pressure switch.
Is this something that you normally remove to make things easier when taking this cover off?
Simon
Old 07-Mar-2014, 09:54 PM
r15suk's Avatar
Sussed it!
You need to lift it up a bit and outwards as there's a tiny half moon cut out in the cover that just clears the top of the switch. Well thats what worked for me anyway
If that's done by design they must have been working to some close tolernaces
simon
Old 08-Mar-2014, 07:50 AM
DSC Member nelly nelly is offline
It is really tight. Became a problem when they switched to the newer style pressure switch. The old one was much lower.
I take the switch off, plug the hole and refit when finished. Makes life much easier.
.....but better in YELLOW, or Bloo and now even RED
www.cornerspeed.co.uk you know you want to
http://www.nolimitstrackdays.com the best trackday organisers in the UK
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2018, Jelsoft Enterprises Ltd. - © Ducati Sporting Club - All times are GMT +1. The time now is 01:28 AM.
