General Motorcycles only
Old 17-Apr-2014, 16:28   #1
Front brake hose setup help?
Going a bit mental on the ST...
Radial front master and M4 Monoblock calipers
Quite fancy having a single hose up to the master but I've seen two routes used so far:
T-piece above the wheel and then two short hoses to the calipers, used this on my Aprilia and it worked a treat and bled quite easily...
Ducati seem to favour using a single hose down to one caliper then a twin banjo and another hose to the other side, sounds a pain to bleed but, is it?
As an aside Venhill now do some nice looking stainless ended hoses where the fittings still swivel, look good - anyone used 'em?
Cheers - Frank
Old 17-Apr-2014, 20:36   #2
Single hose down to RHS caliper than a loop over the guard works fine and bleeds well. Cheaper as well as it's only two lines rather than the three line setup you had on your aprillia
Old 17-Apr-2014, 22:19   #3
Cheers Neil,
Looking at my range of discarded hoses (LOL), I might have an over the wheel line that will work and just need a single long hose to the bar and some fitments.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:53.
