Old 12-May-2006, 20:52   #1
Athelstan's Avatar
ST4s Owners
Reference the front Ohlins.
In the Duc Owners Manual it says that the Spring Preload is set at std 16mm, but can be anywhere between 25 or 10mm.
Q: Which is the stiffer setting - the 25 or the 10mm? As I find that page in the manual a little confusing in the way it is written.
Feedback very much appreciated.
Old 12-May-2006, 21:24   #2
Preload doesn't affect suspension stiffness, it simply adjusts the amount the suspension sags when the rider sits on the bike. You need to adjust the preload so that around 25% of the total suspension movement is taken up when the rider sits on the bike. You can also use preload to alter the ride height of the bike.
See here for some more info..
http://www.promecha.com.au/sag_and_preload.htm
Old 13-May-2006, 01:20   #3
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
25mm is min 10mm max
Old 13-May-2006, 10:47   #4
Athelstan's Avatar
Chaps
I know that:
a) the prelaod relates to the sag
b) that the max is 25 and min 10
But that was not my question:
Q: Which is the the stiffer loading - the 25 or the 10 position?
Old 13-May-2006, 10:51   #5
Ducati Dealer
wilf's Avatar
more preload = less sag
so if you have the spring less 'preloaded' you will have a greater sag reading.
Old 13-May-2006, 12:05   #6
Athelstan's Avatar
Thanks Wilf
The fog has now lifted
