Old 16-May-2006, 19:58   #1
CipiVTS CipiVTS is offline
CipiVTS's Avatar
For all the experts, URGENT question
Hi all
I need a quick advice on:
I have a friend with a 999S 2004 that had a crash a damaged the frame.
He has another 996 2002. Can he use the 996 fram to replace the damaged 999s frame?
What are the difference between the 2 frames?
Thanx
Old 16-May-2006, 20:08   #2
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
not a clue
but i dont think you'd have a chance
Old 16-May-2006, 20:10   #3
CipiVTS's Avatar
Somebody else, please!
I need to give the man some advice
Old 16-May-2006, 20:14   #4
My best guess would be no as well. The 996 frame housed the older desmoquattro engine and the 999S has the newer testastretta engine.
Sorry I can't give you the definitive answer you're looking for.
Old 16-May-2006, 20:41   #5
Id say No.
the diagonal cross member between the v (L) is different i believe, would have to be cut and shut!
Thwre was a 999r frame on ebay...................
Old 17-May-2006, 00:13   #6
CipiVTS's Avatar
thanks andy
[Edited on 16-5-2006 by CipiVTS]
Old 17-May-2006, 00:20   #7
Jon Jon is offline
Jon's Avatar
Mood: Tad more confident
I believe he can fit the 999 engine into the 996 frame. Skidlid has done this I believe with his hybrid 998. but has for swopping frames, I can't see the point. The 99 bodywork just won't fit the 996 frame.
Old 17-May-2006, 00:24   #8
CipiVTS's Avatar
I find it stupid too, but a new 999 frame costs a lot and he already has the 996 one... anyway if it doesn't fit ok and it needs cutting and adjusting, i will really advise him not to do it
Old 17-May-2006, 00:28   #9
I'm unfamiliar with the 2002 996 frame, did it have the dropped tube for the larger airbox as per the Foggy rep frame and the 748R frame and the 748RS frame on my 998 Hybid. If not then fitting an air box along with shower injection may prove difficult.
Also the Testastretta engine uses 2mm larger diameter engine bolts for mounting in the frame compared to earlier 996's , the 748R and 748RS also use tha larger bolts and these were introduced in 2000 so could possibly also be used on the later 996's
When you say frame swap, I would have thought it would be more of a engine swap, as fitting a 999 bodykit onto a 996 frame will give a few headaches as no doubt will fitting the Radiator, headlight and a few other items.
