Ducati Sporting Club
Old 29-Jul-2014, 11:47 AM
Clippy's Avatar
Clippy Clippy is offline
Bikes: 1098
Mood: Enjoying a REAL summer!
Electrical Gremlins
How do folks - long time, no see...!
I'm after some help with an electrical problem on my 1098...
This started with the neutral light not coming on, then the orange warning light flashed up on the dash and the headlamp went out...then the indicators stopped working when the bike was hot etc etc then the bike died - stone dead electrics while in a contraflow on the German Autobahn...not the most fun I've ever had with leathers on?!
The bike's now home and I've replaced the reg/rec and battery as all the symptoms seem to point to the old regulator problem...but there's more...
Fuses 2 and 4 - lights and dash had also blown. I replaced these too, and connected the new battery...and the fuel pump runs continuously without the ignition key even being in...
HELP?!
If I put the key in and switch it on then connect the battery the 2 fuses blow again...
My next step is to take off all the bodywork and check all the wiring loom and connectors for water (it was VERY wet in Germany) or points that could be shorting.
Has anyone lese suffer from this? Is there a list of items to check first to try to shorten the investigation job?
I'm guessing the lighting circuit as that fuse had blown, and the dash plug as that fuse went too, but any clues as to why the fuel pump is running without the key in would be really useful...
I'll try once more for effect...HELP!!!!!!
Looking forward to the impending displays of wisdom heading my way...
Giles
Old 29-Jul-2014, 03:04 PM
Bikes: 748S, HM1100S, DD-A
Sounds like it could be the fuel pump relay has either died or is shorted due to the water.
Dig it out and throw it away - they're less than a fiver to replace.
Ducati 748S | Ducati Hypermotard 1100S | 600-620SS DesmoDue Racebike #111 <-- Sold!! | Avanti Race Parts
Old 30-Jul-2014, 11:57 AM
Clippy's Avatar
Bikes: 1098
That's my start point then...and as the lighting and dash fuses are blowing maybe the headlamp and dash plugs needs investigting too if the realy doesn't cure the problem...
If both these fail to solve the issue it's time to get everything off (the bike that is...?!) and trace the wiring around looking for pinches/rubs/vermin damage etc that could be causing a short...deep joy!
Cheers for the advice.
G
Old 30-Jul-2014, 01:58 PM
They seem to be strange beasts in water!
My Hypermotard often decides that it doesn't want to start because of the immobiliser when it rains; it did it on Monday when I stopped to fill up with petrol! Luckily I keep the override code in my phone so a bit of switch waggling and it was fine. It dried out by the time I got to work as well!
Old 08-Aug-2014, 04:48 PM
Clippy's Avatar
Bikes: 1098
Heeeeelllllllppppp!!!!
I've traced around all the wiring...all looks OK - no pinches, scuffs, cuts or breaks that I can see...
I've replaced all the relays I can find - now at least the fuel pump isn't running all the time when the battery's connected so I guess that one was fubar?!
In desparation as it's still blowing the dash fuse I've removed the dash and opened the back up...and there's a stink of burned TCP and a blue M&M (capacitor if I recall correctly from my childhood radio building) that's burned and split on one side...
Question 1 - does this all sound like a reasonable outcome from the Regulator going pop?
Question 2 - any ideas if this would also cause the lighting fuse to blow repeatedly?
Question 3 - if I need to replace the dash, do I also need to replace all things relating to the immobiliser - keys, ignition barrel sensor, locks etc or can another dash be programmed to match my keys?
Question 4 - any ideas where I can get whatever I need cheap?!
Here's hoping that you guys and girls come up with the answers as usual...?!
Giles
Old 08-Aug-2014, 06:40 PM
chrisw's Avatar
chrisw chrisw is offline
Bikes: 999 Mono/1198S
This guy is the cheapest I have found for new dashes
http://www.ebay.co.uk/itm/2612984267... 4.m1423.l2649
To program the dash and your keys you need the code card for the bike.
Old 08-Aug-2014, 10:58 PM
Clippy's Avatar
Bikes: 1098
Cheers for the link Chris - I've not used ebay to buy abroad before but guess there's no reason to assume it should be any less reliable than buying in the UK...
For anyone interested in the damage I've attached a photo or two...
G
Old 09-Aug-2014, 10:35 AM
chrisw's Avatar
Before you write the dash off have a word with Mark at Scorpio http://www.scorpio-electronics.co.uk/pages/contact.php
It may be repairable.
  #9
Old 10-Aug-2014, 05:03 PM
Clippy's Avatar
Bikes: 1098
Thanks Chris - e-mail sent to Scorpio...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2019, Jelsoft Enterprises Ltd. - © Ducati Sporting Club - All times are GMT +1. The time now is 08:14 PM.
