Old 30-Aug-2006, 14:34
900MAN's Avatar
900MAN 900MAN is offline
Mood: 900 went 999 gone, Multi came and went, 749 Nero now
Pressure Plate Bearing
How much hassle is it if you buy a pressure plate without the bearing?
Ta
Old 30-Aug-2006, 15:06
Push out, push in from what I have seen!
Old 30-Aug-2006, 15:29
900MAN's Avatar
Just wasn't sure if you need any special equipment.
Mallet and wood time then (when I get the bits)
Old 30-Aug-2006, 16:18
Don't think you even need that much!
Old 31-Aug-2006, 00:24
Paul James's Avatar
Founder Member
Probably pay to warm the plate in the oven before fitting the bearing as the fit is a slight interference, with manufacturing tolerances you could get one on the tight side.
http://www.multirole-eng.com
Old 31-Aug-2006, 00:38
final_edition's Avatar
Or put the bearing in the freezer overnight.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:29.
