General Motorcycles only
Old 16-Dec-2006, 00:35
Trig's Avatar
Trig Trig is offline
Bikes: Ducati 999, BSA A65 Lightning, Matchless G80s
Mood: Fed up with DIY!
Smile MPL Clutch Basket
I am thinking of buying the type with the titanium inserts. Has anybody tried it? Does it reduce clutch rattle?
Old 16-Dec-2006, 09:39
marko's Avatar
marko marko is offline
Mood: happy
Ian748 bought one last summer off eBAY, gets on fine with it ,I think he had to have a bit of machining done first off to make it clear the cover.
Old 16-Dec-2006, 16:41
Yeah,I think they are made to match MPL's own clutch covers.
Old 16-Dec-2006, 22:01
Ray's Avatar
Ray Ray is offline
Had one fitted one to a 998r, the standard cover didn't fit but nothing that some spacers didn't cure. I think it make the the clutch a bit quieter but changing from a well used basket to a shiny new one with do that anyway.
Please with it so far.
Ray
Old 16-Dec-2006, 23:31
Ian 748's Avatar
Ian 748 Ian 748 is offline
As the lads say, I’ve been using one for a while now with no probs at all. I had ally st plates fitted at the same time so I can’t say if it’s any quieter in its own right but with these plates it makes a lot less racket.
I also use a non Ducati open half cover that is fitted with no gasket and did require machining a tiny amount to make sure I had just a tad clearance. Bling factor is minimal as you don’t see anything of it really which is a shame because it’s nice bit of kit. I picked mine up for less than the cost of the standard Ducati part so good value for money especially as the inserts can be replaced if and when you need it.
Old 17-Dec-2006, 10:47
Trig's Avatar
Thanks for the info. I want to get an open cover and pressure plate too so I might as well get it all from MPL.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 02:21.
