Old 28-Feb-2016, 13:03
bally71's Avatar
Mood: Inquisitive cat
Forks alordy
Can some one confirm for me that the ST forks work ok on the ss .. i bought them for the monster but since i'm sticking with the ss now and my current ones are pitted to buggery from riding through gravel traps, i thought i'd use them.
They will be going off to maxton to get fettled first so no worries about springs .. just wanted to make sure there's nothing i've not considered.
Old 28-Feb-2016, 15:01
Yes, they are the same diameter so will fit. They're just a bit longer so you'll need to put them through the yokes a bit to take this into account and setup your ride height properly.
Old 28-Feb-2016, 16:43
bally71's Avatar
Cheers Antony but the ST forks are 40mm shorter not longer
Well the ones i have are ...
Old 28-Feb-2016, 16:56
All ST and Monster forks are shorter than the SS versions as the SS bikes have the bars clamped to the top of the fork above the top yoke
Old 28-Feb-2016, 18:22
paynep's Avatar
Mood: Wet wet wet
I've just changed from SS to ST in my bike. I used the ST internals with my SS springs, just with the preload spacers 40mm shorter in total.
Everything seems to have set up fine but I wont know for sure until Brands....
15th year in DD #68 and getting slower by the year
Old 28-Feb-2016, 18:32
bally71's Avatar
Cheers guys
Yes my ss forks where 45mm above the yoke.
40mm is standard i think plus i dropped them 5mm to sharpen it up.
The ST forks seem perfect .. it's as if ducati knew.
Old 02-Mar-2016, 12:39
badgerpilot's Avatar
Bikes: Badger DD A #50, Multistrada 1200s, Aprilia Tuono 1100rr
Forks, are they the boingy tube things with a wheel at the end?
Scott #50
Old 02-Mar-2016, 19:31
bally71's Avatar
In your case mate they are the pointy sharp things with sausages on the end
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:23.
