Ducati Sporting Club
Home Calendar Gallery Membership Online Shop DSC Blogs Extras
Go Back   Ducati Sporting Club > General > Ducati Press Releases
Reload this Page Ducati Press Rel. - 2008MY - 848 and variants
Forum Home Register FAQ Search Forum Recent Posts Mark Forums Read
Ducati Press Releases Information from the Factory and Ducati UK.
ALL text and photo's published here by the webteam is copyright of Ducati and cannot be used without their express permission.
Old 06-Nov-2007, 11:47 AM
DSC Member Iconic944ss Iconic944ss is offline
DSC Webteam
Bikes: 1993 - 944ss / Aprilia Falco / ST4S
I know - an 848 forum will be needed eventually
Enjoy - Regards - Frank
All items copyright Ducati.
DUCATI SUPERBIKE
The Superbike family for 2008 features two important changes: the introduction of a mid-engine size version, the light and nimble 848, and an extreme ‘racing’ version for all those who demand the maximum performance, the 1098 R version that will take part in the 2008 World Superbike Championship.
The priority in every step of the new Ducati Superbike development has been performance first. Every system, every detail and every component has been studied, pared down to its essence and performance increased to the maximum. If it didn’t make our Superbike lighter, faster or deliver quicker lap times, it wasn’t considered. The 848 and 1098 are the lightest, fastest stopping, quickest lapping Ducati Superbikes in history. For the first time Ducati MotoGP and World Superbike technology have been combined to create premier sport bikes. The results are stunning.
The look and stance of the 848 and 1098 were designed by the combination of race track technology, track-derived components and Ducati heritage. Their striking aerodynamic shape naturally embraces a riding position, configured by our racers and test riders for optimum speed and agility. The racing spirit takes form.
The new Ducati Superbikes immediately strike you with their purposeful, no-nonsense attitude. Performance is first and foremost in every detail.
Trademark Ducati features like the high tail section and compact front-end meld with twin under-seat silencers and single-sided swingarm to express aerodynamics and agility. Add the new Testastretta Evoluzione engine at the heart of the machines and you get all-out performance Ducati Superbikes that seem to be moving fast, even when at rest.
A number of ‘firsts’ for Ducati and production sport bike design have been introduced. The 848 and 1098 are the first to have a data acquisition system integrated as standard equipment and the first to use an ingenious construction method for their weight-saving single-sided swingarm. More ‘firsts’ for a road-going Ducati include the direct application of MotoGP technology, like the power producing GP6-derived elliptical throttle bodies and the use of the information-rich instrumentation originally developed for the Desmosedici GP7. Furthermore, the 1098 is the first production motorcycle to have the amazing stopping power of Brembo Monobloc brakes.
DUCATI 848
As agile and light as a Supersport, as powerful as a Superbike
The new 848 enjoys all the performance advancements of the entire Superbike family, while adding its own innovations to redefine the middleweight sport bike class.
The words ‘agile’ and ‘refined’ aptly describe the 848. At 168 kg (369 lbs) the 848 is an amazing 20 kg (44 lbs) lighter than its predecessor, and a significant 5 kg (11 lbs) lighter than its larger capacity brother, the 1098.
The highly advanced 848 engine uses an improved method of engine case production in which cases are vacuum die-cast formed. While providing significant weight savings of more than 3 kg (6.5 lbs), this method also ensures consistent wall thickness and increased strength. Further refinements include a sophisticated wet clutch that offers 1 kg (2.2 lbs) less weight, a much higher service life, improved clutch feel and quiet operation.
With the first twist of the wrist, the powerful rush of the Testastretta Evoluzione engine confirms that the rules have changed. The 848’s 134 hp is not only 30% more powerful than its predecessor, but it provides a power-to-weight ratio even better than the potent 999.
The new engine
The new 848 Testastretta Evoluzione engine becomes the benchmark for the middleweight sportsbike category, benefitting from all the experience accumulated with the larger engine on the 1098. It successfully adopts the same design guidelines and the same compact cylinder and cylinder head layout, but introduces for the first time ever an innovative solution for the crankcase, which has been designed with a further weight reduction for this advanced engine in mind. The overall layout of this engine integrates a series of avant-guard solutions, confirming the close links with the experience of Ducati’s racing department.
The 849 cc engine has bore and stroke values of 94 mm and 61.2 mm respectively, which produce a ratio that is only slightly inferior to the 1098 (1.54 compared with 1.61), while maintaining the highly ‘over-square’ layout typical of racing engines.
Power output is an impressive 134 hp (98.5 kW) at 10,000 rpm and maximum torque is 9.8 kgm (96 Nm) at 8250 rpm. The power and torque values confirm the high performance level of this engine, especially when compared to its predecessor, the Testastretta-engined 749.
The cylinder head has been modified in line with the characteristic bore and stroke of the engine in order to optimize the fluid dynamics of the intake (straight and plunging) and exhaust ducts and combustion chamber. The compression ratio is 12:1.
The valve angle is the same as the 1098 engine and diameter is 39.5 mm for the inlet valve and 32 mm for the exhaust. The technology used sees the application of a bi-metallic alloy that combines increased lightness with resistance and reliability required for these particular components. The desmodromic control system has also been designed with the weight and the inertia of the new components in mind, allowing extremely efficient valve lift during intake and exhaust phases. The excellent results achieved are confirmed by the engine’s power figures, producing outstanding performance thanks also to the use of MotoGP-derived elliptical throttle bodies, which have been fitted to the 1098 engine.
The design of a dedicated elliptical throttle body for the 848 demonstrates the attention that Borgo Panigale engineers have devoted to the development of the Superbike range. The cross-section is reduced from the 60 sq. mm of the 1098 to 56 sq. mm so as to optimize fluid dynamics at every engine speed.
Just like on the 1098, the new cylinder heads benefit from fewer components and include magnesium covers.
For the first time ever, this Testastretta Evoluzione engine sees the introduction of a special technology for the construction of the engine crankcase: Vacural? casting. This is a forced vacuum die casting method that allows jet characteristics to be improved thanks to the absence of porosity, gas inclusion and oxidation. This allows extremely high measurement precision and greater ductility for aluminium alloy. Designers have been able to harness the benefits of this innovative process by redefining the shape and the wall thickness of the new crankcase by means of FEA (Finite Element Analysis) checks, which allowed the required reliability standards to be achieved, while simultaneously obtaining a significant weight saving of 3.5 kg.
The 848 engine is fitted with a silent modular wet clutch, characterized by an exceptional resistance to wear that will lead to superior duration. This solution makes a useful contribution to weight saving, estimated to be around 1.6 kg, which is also due to the use of a different type of clutch cover.
The high power figures achieved by this engine also come from the use of the same type of oil cooler and coolant radiator as the 1098’s engine, with an increased surface area assisted by lightweight, high flow electric fan assemblies.
Finally, the 848’s exhaust system follows the same layout and uses the same innovative technology as the 1098. The system terminates with Ducati’s trademark twin under-seat silencers, delivering the unmistakable signature sound of the big bore 90° L-Twin.
This power unit, just like all the other Ducati engines, has been designed to comply with Euro 3 exhaust emission norms.
Chassis
Trellis frame
Developed in cooperation with Ducati Corse, the 848 Trellis frame has a simplified tube layout featuring main section tubes increased in diameter from 28 mm to 34 mm, while being reduced in thickness from 2 mm to 1.5 mm. The result is a 14% increase in rigidity and a weight saving of 1.5 kg (3.3 lbs).
Single-sided swingarm
The 848, as all the Superbike family, is equipped with a unique single-sided swingarm. The engineers were encouraged to re-think the construction technique of this element. The solution was to produce the main operational components using individual aluminium castings so as to ensure strength around the pivot points, wheel hub and suspension links, with fabricated aluminium sections used to complete the construction into a single, beautifully engineered component.
Rear suspension
Highlighting the way in which individual components are influenced by each other, the new lightweight Trellis frame and single-sided swingarm have enabled a more compact and further weight-saving rear suspension linkage system to be used featuring separate lower pick-up points for the push-rod and suspension unit. This ‘tandem’ design effectively reduces stress around the linkage pick-up area of the Trellis frame. Working together with this highly efficient linkage is a fully adjustable Showa single shock for the 848, the same as the 1098.
Front suspension
At the front the new 848 is equipped with fully adjustable 43mm Showa forks with radial mounts. This type of front suspension is professionally track-tuned and offers superior road holding, delivers superior feedback, and helps every rider to be more confident and in control.
Control
Brembo Monobloc calipers
The 848 brake system is characterized by M4 calipers using four 32 mm pistons and two radial mounted pads. Matched to the calipers are two 320mm discs and the combination of these elements achieves spectacular braking power.
Super lightweight wheels
The new 848 also benefits from lightweight Marchesini Y-shaped spoke wheels. The weight saving of 250 gr achieved on the front wheel substantially reduces the moment of inertia and enhances the 848’s change of direction and braking performance. The rear wheel is just as impressive with a complete redesign for its single-sided swingarm application that has resulted in a reduction of over 1 kg compared with traditional Ducati single-sided swingarm fitments. Finally a 5.50” wheel fitted with a 180/55 tyre guarantees the maximum agility at the rear.
All the information is available at http://www.ducati.com/en/bikes/index.jhtml
COLOUR SCHEMES
Fairing Frame Wheels
848 Red Red Black
Pearl white Racing Grey Black
1098 Red Red Black
Yellow Racing Grey Black
1098 S Red Red Black
Black Red Black
1098 R Red Red Racing Gold
Click image for larger version Name:	SBK 848_08S_motore_B01 [558x419].jpg Views:	91 Size:	63.4 KB ID:	6479  Click image for larger version Name:	SBK 848_08S_PW_H01S [558x419].jpg Views:	105 Size:	66.1 KB ID:	6480  Click image for larger version Name:	SBK 848_08S_R_F01S [558x419].jpg Views:	100 Size:	89.4 KB ID:	6481
Cheers - Frank
Old 06-Nov-2007, 12:04 PM
DSC Webteam
More pictures.
Click image for larger version Name:	SBK 848_08S_PW_H01S [558x419].jpg Views:	77 Size:	66.1 KB ID:	6489  Click image for larger version Name:	WMK_MY08_SBK-848-02.jpg Views:	93 Size:	90.7 KB ID:	6490  Click image for larger version Name:	WMK_MY08_SBK-848-03.jpg Views:	86 Size:	133.2 KB ID:	6491
Cheers - Frank
Old 06-Nov-2007, 12:14 PM
Mark's Avatar
Mark Mark is offline
That middle picture, looks like a cbr125. How slim does that look!!
Old 06-Nov-2007, 12:35 PM
I think this could be my next bike, but NOT in white!! Guess it depends what it looks like of race-repped, coz that plain clouour is deperate for something!! would have preferred yellow, follwing the 748/749 tradition that they should be yellow
Old 06-Nov-2007, 12:49 PM
Chaz's Avatar
Chaz Chaz is offline
Bikes: 916 Strada
Mood: www.od2racing.co.uk
White must be the new base coat
Old 06-Nov-2007, 08:45 PM
I'm impressed by this bike, it gives me a woodie
One day ...
Old 06-Nov-2007, 08:54 PM
Mark's Avatar
One day ...
What, one day you'll get a woodie?
Old 06-Nov-2007, 08:59 PM
One day, you'll be funny! Yeah ok, I didn't believe that either ...
knob!
  #9
Old 06-Nov-2007, 10:06 PM
Mark's Avatar
knob!
  #10
Old 26-Feb-2008, 12:15 AM
lane748's Avatar
lane748 lane748 is offline
Mood: mmmm....yellow!
a yellow one would look cool:
Click image for larger version Name:	big17.jpg Views:	69 Size:	57.3 KB ID:	8049
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2018, Jelsoft Enterprises Ltd. - © Ducati Sporting Club - All times are GMT +1. The time now is 03:07 AM.
