General Motorcycles only
Old 14-Mar-2004, 08:54
Glyn's Avatar
Glyn Glyn is offline
Mood: st2......we can rebuild
is my chain dead
i used to adjust my chain about once a month ish
always keep it clean,oiled and lubed. all of a suden i seem to be doin it every couple of days.
whats caused this, natural wear and tear,riding it all winter or do they just do that sir,dont think im over tightening. i do it at 30mm from center (the pin bit)of chain pulled down then pushed up.
its done about 11.5k still lots of adjustment left but going through it quick.
Old 14-Mar-2004, 09:17
Mood: Avatar what Avatar
I supose it depends on how hard you ride as well. I would have thought with 11.5 k it would put your mind at ease if you changed the chain and sprockets not big money !!
Old 14-Mar-2004, 09:55
Lay it down & poke it with a stick , if it does not bite back, it`s dead
Old 14-Mar-2004, 10:13
Blat182 Blat182 is offline
Are you remembering to tighten the pinch bolts after you have adjusted it
Old 14-Mar-2004, 10:16
I'm starting to sound like a broken record on this one!! Next time you go to Nellys get him to fit a Scotoiler. Done 7000 miles on mine with no chain adjustment needed so far.
Old 18-Mar-2004, 19:58
Glyn's Avatar
o.k it's dead
the bikes a 2001 st2
so is it x-ring or o-ring
is there any other alternitive to d.i.d
do i also need to replace sprockets
where's the cheapest place/site to order
thanks
Old 19-Mar-2004, 11:52
Fordie's Avatar
Fordie Fordie is offline
Regional Organiser - BHCN
Mood: Raring to Ride
Glyn, Ive had to change both the 900SS and the 996 chains laterly. About £126 fitted for the 996,the Vtwins are heavy on chains as well as tyres. I got about the same mileage as you 10/12000. Check that you hav'nt got a tight spot so when you check it in differant places you ar,nt getting a false reading each time.
But having said that if you do have one then the chains naf any way.Theirs no good news either way. 4D
[Edited on 19-3-2004 by Fordie]
Old 19-Mar-2004, 12:43
Glyn,
Not much comfort I know, but that sounds about right for an ST2 chain. I got mine changed at it's big service with Nelly. The bike had done about 12.5K, so a little bit more mileage than yours (which isn't bad when you consider my bike has a much bigger engine than yours ).
Neil used a Tsubaki chain and Renthals sprockets on mine - cost me around £130 or thereabouts. You'll need to change the lot because new chain on old sprockets = premature wear
  #9
Old 19-Mar-2004, 16:27
Glyn's Avatar
ok new sprockets as well then
whats the score with fitting different size than standard on an st2
is it worth trying a 14 on the front??
  #10
Old 19-Mar-2004, 20:50
Athelstan's Avatar
12000miles
Glyn - my chain was regularly tensioned, lub'd etc and developed tight spots etc just before the 12k service. It seems from all the posts that that is about the distance for a chain on the ST series - mine's an ST4s.
At the time of changing I had a Renthal 15T front sprocket fitted and a std rear, plus the Tsubaki 102L chain - total bill = £126.74
Hope that helps.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:40.
