Old 02-Apr-2004, 11:00
Ian900SLV Ian900SLV is offline
Mood: All SP'ed up at the moment
Mirror extension blocks
Hi guys,
anyone know where I can source a set a mirror extension blocks to fit on the SL.
I am sick of looking at my elbows
Ian
Old 02-Apr-2004, 11:47
It was such a long time ago....
I think I got mine from Brancato engineering....
http://www.brancatoengineering.freeserve.co.uk/
Could be wrong....
Good luck
Old 02-Apr-2004, 11:53
Good grief I was right for a change.....have a piccy even............
Frank
Old 02-Apr-2004, 13:15
Cheers Frank,
I thought you might have the answer
I`ve sent an email off to enquire
Ian
Old 02-Apr-2004, 13:23
Derek's Avatar
Derek Derek is offline
Bikes: ST4s ABS
They are plug ugly things - like club foot boots for mirrors.
I've had them for a couple of years and I'm seriously thinking of taking a band saw to them and cutting them so they taper off to the rear. This won't affect their extension properties but will hopefully make them slightly more aesthetically pleasing.
Old 02-Apr-2004, 17:23
Phil Butler Phil Butler is offline
Bikes: ST2, 750ss, 350 Forza, W650, CB250RS, 5x Royal Enfields
Mood: Nesun Dorma
How are you going to taper them Derek? mine are Brancato and are hollow inside with reinforcing struts, are yours from another source?
Phil
Old 02-Apr-2004, 18:20
martin hughes martin hughes is offline
The Brancato extensions work OK but are ugly. I have fitted VFR 750 (CBR 600) pattern mirrors - needs an extra screw hole in the fairing but they work well.
Old 02-Apr-2004, 20:04
FiscusFish's Avatar
Picture?
  #9
Old 03-Apr-2004, 23:12
Bar end mirrors seem to be all the rage in the USA ?????
Dunno about on a Duke mind
  #10
Old 05-Apr-2004, 09:29
Derek's Avatar
Bikes: ST4s ABS
Phil
Mine are from Brancato too and similarly constructed but if I cut the rear of them, i.e. the part which abuts against the fairing, then the external apearance will be un-affected.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 22:01.
