  #11
Old 31-May-2004, 08:56
Mood: going for a ride...
Originally posted by jk2
Originally posted by yellowisfriedegg
Originally posted by Twinfan
Cheers. Anyone dropped one at the front on an '04 749S? Is it worthwhile?
I went down 1 at the front and 1 up at the rear on my 999S , noticably quicker acceleration , reduced top speed by 5-10 mph though.
I intend doing the same on the 749R , I'm just waiting for sprockets
I have a 999s, with 1 tooth less on the fr sprocket, how much more difference does going up one on the rear make? Any problems with chain length?
One down at the front and 1 up at the back is the equivalent of 3 (and a bit) up at the back , the advantage being you do not need a new chain to do it where you probably would have to replace the chain too if you just altered the rear sprocket.
In reply to Shazzams post , I will check the front sprocket on Mrs eggs 749S when I get home for number of teeth , I thought it was a 15 front standard so going down to a 14 is not an issue , I do know without checking though that ALL 749's and 999's come fitted with 525 chain and sprockets as standard.
[Edited on 31-5-2004 by yellowisfriedegg]
  #12
Old 31-May-2004, 15:23
You're right, I had forgotten that the 749’s get 525 chains. Probably more for parts standardization than for strength requirements. I remember from the product introduction that that was one of the major design objectives of the new models.
  #13
Old 31-May-2004, 16:11
According to the info I have here all the 749's have a 14T front. 13T are like hens teeth and run the chain too tight. Only real world alternative is to up the rear. 3T is a good start, and you may get away with the standard chain?
Both Renthal and STM do alloy real sprockets for them now. Rentha are about £25, the STM £58 but are real works of art
  #14
Old 04-Jun-2004, 21:36
Mood: Diet
Looking at ducati.com (not sure if this is accurate)
749S has 14F 39R with primary drive 1,84 (is this 1.84:1 ? )
749R has 15F 35R with primary drive 2,11
I not sure which way the maths goes, so which has taller gearing ?
Rob
  #15
Old 05-Jun-2004, 08:07
749R 749R is offline
Mood: Waiting for Sunshine
If it's any help, I went up 3 teeth on the back, the gearing is spot on now and still using the standard chain.
  #16
Old 05-Jun-2004, 08:24
When you say still using the std chain to get an extra 3 teeth in. How much did you move the rear wheel forward then? which mark are you on on the swingarm? Any piccies?
  #17
Old 05-Jun-2004, 15:01
749R, going from a 15/35 to a 15/38 using the same chain will shorten your wheelbase 12mm. In general, it's better to go to a longer wheelbase than a shorter wheelbase because it improves high speed handling. Superbike corsa swingarms, for example, are 15mm - 25mm longer than street versions for this reason. Shortening the wheelbase beyond the stock setting is really not a good idea.
A good approach gearing is to set the wheelbase at maximum (still allowing the adjuster an additional 10mm for chain stretch) and then use a combination of sprockets and chain length to shorten the gearing.
The length of each link from pin-to-pin for a 5XX chain is 5/8-inch (16mm.) So in your case of using a 15/38, if you use the next longer length (adding two links at a time) you’ll get a wheelbase 4mm longer than stock instead of 12mm shorter. I’d do it.
  #18
Old 05-Jun-2004, 15:56
We knew that........
  #19
Old 05-Jun-2004, 16:02
I'll get me coat ...
  #20
Old 05-Jun-2004, 16:29
er... not really...
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:11.
