Ducati Sporting Club
Home Calendar Gallery Membership Online Shop DSC Blogs Extras
Go Back   Ducati Sporting Club > Model Specific - Discussion, Technical Problems and Help > 851 / 888
Reload this Page clutch fluid contamination
Forum Home Register FAQ Search Forum Recent Posts Mark Forums Read
Old 27-Jan-2009, 08:23 PM
keith888's Avatar
keith888 keith888 is offline
Mood: On the up
Hi Guys,
Can anyone can identify the source of this light coloured fine 'stuff' that has slowly been accumulating in bottom of the 888's clutch hydraulic reservoir over the last couple of years? Hopefully more obvious on the photo. I always thought that the clutch fluid on Ducatis went black but (after 3 years) mine was still only a dark straw colour. I'm running a standard clutch slave that I rebuilt 3 years ago. Now cleaned (no sign of any leakage from the slave), fluid changed and all is fine but I'm curious.....
Thanks,
Keith
Old 28-Jan-2009, 10:55 AM
gordonparker's Avatar
Could be that the fluid is breaking down, normally you should change your fluid every 2 years regardless of use as I belive it will absorb moisture which in turn will affect the performance ???
Gordon
Old 28-Jan-2009, 01:49 PM
I agree with Gordon. Moisture laden air is bound to get into the system over the course of a couple of years. Hydraulic fluid is very hygroscopic and will absorb the water from the air (that's why you always have to use fresh fluid rather than stuff from a can that's half empty).
The 'stuff' could just be emulsified fluid, but it's a good idea to flush it out because when the fluid gets hot the water in it will vapourise, and because you can't compress liquid but you can compress gas, the lever will get very soggy.
Not so much of a problem with your clutch, but with your brakes
___________^
Old 28-Jan-2009, 02:02 PM
keith888's Avatar
Mood: On the up
I'm certain its not the (5.1) fluid breaking down. I've certainly never seen anything like that before on fluid that was much more than 3 years old. The brakes were done at the same time certainly nothing nasty flushed out of that system so it seems to be something unique to the clutch system.
Keith
Old 28-Jan-2009, 10:57 PM
Scooter916's Avatar
Mood: Hmmm Conference season
Just athought, When you rebuilt the Clutch slave, Did you smear the seal in Grease??? it could be the grease finding its way back up the line.
Is 5.1 Compatable with the plastic pot????
Glyn
Old 29-Jan-2009, 11:54 AM
keith888's Avatar
Mood: On the up
Hi Glyn,
I only used brake fluid on the slave bore and piston seal as per manual. I did, however, put a fair bit in the cavity between the top of the piston and the seal that the push rod passes through. I did get a bit of air out when I was flushing the system so maybe my slave seal is actually on the way out (even though not dripping) and some of that grease got sucked into the system at some point?
Keith
Old 29-Jan-2009, 12:24 PM
007's Avatar
007 007 is offline
Bikes: 996 Bip
Mood: CITIUS EST MELIUS!
Hello Keith,
dot 4 (glycol based, boils at 230C)
dot 5 (silicone based, boils at 260C)
dot 5.1 (glycol based, boils at 270C)
Dot 4 & 5.1 are both glycol based and therefore hygroscopic.
Dot 5 is a silicone blend, and is not hygroscopic, but can cause premature wear in seals, as moisture is forced into the rubber or plastic. They are also more compressible.
Mixing DOT 4 & 5.1 is fine, but if yor wish to consider a silicone blend, you will need to flush the system, or you will experience a chemical reaction causing solids to precipitate out of the mixture and clog up your braking system.
Best regards.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2019, Jelsoft Enterprises Ltd. - © Ducati Sporting Club - All times are GMT +1. The time now is 04:13 PM.
