Old 04-Apr-2009, 09:37
james81273's Avatar
james81273 james81273 is offline
Mood: twitching
Question 1198 cooling fan constantly runs even when cold?
anyone had any issue with the cooling fan constantly running when the battery is re-connected? The bike is stone cold (not used for 24 hours) but as soon as the battery is connected it starts straight away...and the battery is drained after a short while because of this.
weird? No fault codes either on the dash.
Old 04-Apr-2009, 09:59
james81273's Avatar
Mood: twitching
forget it just reconnected the battery after a nights charge and although the fan kicked into life it stopped as i was tightening the terminals. Arrhh the charm of a new bike..hmm
Old 26-Apr-2015, 12:27
chillo's Avatar
chillo chillo is offline
Hi All,
Found this post by searching t'internet!
Have got exactly the same issue after replacing my rad on my 1198!
When I connect everything back up my fans are permanently on even with ignition off!
Any ideas?!
It maybe shorting somewhere but have only disconnected the fan connectors etc!
Old 26-Apr-2015, 22:16
Be worth checking the Fan relay, it may have packed up
Old 03-May-2015, 09:01
chillo's Avatar
Sorted it by connecting everything up with fan fuse removed, fired it up and let it get to 108C then put fan fuse back in (wouldn't go past 62-64C with fuse in)
Bike cooled down and fan switched off when it got back below 100C. Think it needed to complete a cooling cycle to reset the fan relay as it had gone over 100C previously when I holed the rad.
Old 03-May-2015, 21:32
chrisw's Avatar
chrisw chrisw is offline
Bikes: 999 Mono/1198S
More likely the relay has dried out as they are prone to moisture and Verdi Gris.
They cost £1.99 off eBay. It is the first of the two relays on the side of the battery box. Buy 2 relays and replace both, better still buy 3 and put a spare in the tool box.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:54.
