Old 08-Jun-2009, 10:39
DannyBicknell's Avatar
DannyBicknell DannyBicknell is offline
Bikes: Ducati 749 Monoposte
Mood: Ducati On The Brain!
749 Tank Range
Hi Guys, What sort of range are you getting out of a full tank on your standard 749, mine is going into the dealer later in the week to be re-tuned, but I was wondering whether it is a bit thirsty or not? I am getting the light come on at 70 to 80 miles and working it out, will run dry at 110 to 120 miles. This is general riding including motorway cruising.
Old 08-Jun-2009, 12:40
Nev748's Avatar
Nev748 Nev748 is offline
Bikes: ex1098, ex748s,ex 999s, now 916 SP3
I would guess that is thirsty. My 999s has a 67mm Leo Vinci exhaust system,ecu and DP air filters. Been dyno'd at 145bhp at the back wheel and my fuel light comes on at pretty much 85 miles every time.
Old 08-Jun-2009, 13:29
It does sound as if the bike is using a lot of fuel,.....are you sure its up to the brim when you fill up?
Mind you,those fuel level sensors can be a bit hit or miss.
As a comparison,my 999S with assymetric system will do,on average,100 miles before the light comes on.If I'm 'trying',I can get the light on at around 75 miles.
Old 08-Jun-2009, 14:20
MSO 749s's Avatar
MSO 749s MSO 749s is offline
I get about 100 miles from my 2005 749s, general roasd use.
Old 08-Jun-2009, 17:16
Murray Mint's Avatar
Sounds about right, that's what I used to get.
Old 08-Jun-2009, 18:44
Glyn's Avatar
Glyn Glyn is offline
Mood: st2......we can rebuild
always 80-85 miles
749s 54mm full system and chip
Old 08-Jun-2009, 20:15
Thanks Guys, sounds like it is a bit thirsty I just wanted an idea so I can tell the dealer when I take it back, it is cutting out on tick-over and also backfires around 4000 rpm, so they are going to re-tune. Will let you know the result.
Old 09-Jun-2009, 14:35
MSO 749s's Avatar
Hmmm. Mine cuts out on tickover sometimes, usually when at the lights next to a moped... Look like a right tit.
Regards
Mark.
  #9
Old 09-Jun-2009, 18:23
RedMist's Avatar
RedMist RedMist is offline
Bikes: Monster S4R & 749S
Mood: Mellow Yellow
100 miles fuel light comes on - 2004 749s standard exhaust
  #10
Old 09-Jun-2009, 20:43
bigtwin bigtwin is offline
999s with asymetric termis - anything between 85 - 115miles when the low fuel light comes on. You will get quite a low figure if you dont brim it when you fill up. I always sit on the bike holding the bike absolutely vertical (hell I sometimes get fuel coming out the overflow when I park it back on the stand).
Do you fill it up on the sidestand?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:04.
