Old 10-Jun-2009, 18:50   #1
moozaad moozaad is offline
Bikes: Ducati ST2
Mood: Fruity
Triton Chips
Has anyone used one? Ebay Italian Supplier
Is it the equivalent of a FIM 161?
Old 15-Jun-2009, 17:49   #2
pcn1 pcn1 is offline
pcn1's Avatar
Seems cheap if it deliver's what you would like.
My FIM was £125 IIRC, but that did come with a claimed 6 to 8hp if used with after market pipes.
I would say it was the best money i spent on the bike as it really helped to smooth out the power delivery.
Dont Ducati performance also do a chip ??
Old 15-Jun-2009, 18:14   #3
Bikes: Ducati ST2
Mood: Fruity
Does FIM still exist as I couldn't find any info on it unless it's the federation international motorcycles or whatever it is in french
Also did you have to have it setup or was it just drop in? iirc, ST2 only have 3 adjusters, CO2 trim, idle rpm and idle mixture - so it can't be too hard with a co2 meter to setup if using a preconfigured map.
Really I'm not looking for more power, I just want to smooth it out a bit.
Old 17-Jun-2009, 20:29   #4
pcn1's Avatar
They are still around, "Protwins" are an agent and so is Sigma performance.
Find Ultimaps Australian homepage and you can see all the power graphs and stuff (I havn't looked in years thought !).
Basically they make therir chips by getting volunteers to give them their bikes so they can map a "real world" chip for a standard bike.
You can just pop it in and go, but to get the best from the bike have the throttle bodies balanced and the co2 trim done at the same time.
I did all this myself (and Im no expert) and it was a revelation the smoothness and better power. Do you run a 14 tooth sproket up front? This helps as well.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:18.
