Old 22-Jul-2009, 10:51   #1
hawkati hawkati is offline
Bikes: ducati 996, hawkati, kawacati
hawkati's Avatar
Mood: generally vile and mischevious
dragging plate
shredded a numberplate again on monday, and whilst one reason would be a 190/55 tyre, and another being the bike not being set particularly high at the back.......a brief check of other 916/996's shows that the numberplate bracket appears to be about 1/2 inch lower than on other bikes, as if it's dropped.
i'm wondering if the plastic undertray that the numberplate bracket is attatched to has gone a bit soggy with heat from the exhausts.
anyone else has this, or is it just me?
cheerdy, j
Old 22-Jul-2009, 11:47   #2
Gobert23 Gobert23 is offline
Gobert23's Avatar
D'you have a picture? I've not seen or heard of this happening before, but will always be proved wrong...
You'll be able to pick-up a stock/OE undertray, no worries (and at a fraction of the cost of a C/Fibre item).
Have you checked where you're ride-height adjust is as well? Sag and Pre-load?
G
Old 22-Jul-2009, 12:07   #3
hawkati's Avatar
heya - no picture, i'm afraid - strictly old skool film - i get pics on disc as well, but can't upload them at work - curses!
...anyway, all i can judge it by is that when plate got shredded on monday, i was at lucie's funeral, and there were a few other ducati's (i noted a particulary flash looking yellow one with all the bells and whistles), and the number plate light was, by rule of thumb, about 1/2 inch lower than on any of the other 916/996/998's i saw.
since the bracket itself seemed fine, i'd wondered whether the undertray it was bolted to had warped.
not very scientific i know, but summat needs doing - that's the 3rd time this has happened - erk.
certainly not going to wind on any more preload - i'm a lightweight, and get bounced around quite enough, thank you, but i'm tempted to go at the link rod with spanners and raise that by, ooh, 5mm - that should work out about 15mm increase in ride height, methinks?
any advise muchly appreciated - i've had the bike about 3 years, and apart from softening suspension a bit from previous owners settings i've left well alone, since it has worked fine on road and track. cheers, j
Old 22-Jul-2009, 13:19   #4
RickyX RickyX is offline
RickyX's Avatar
Possibly your chain adjuster eccentric is incorrectly positioned with the spindle in the 9 o'clock to 3 o'clock sector?
The wheel would therefore be closer to the numberplate and could cause the damage?
Option "b" is: get a smaller numberplate??
Old 22-Jul-2009, 14:13   #5
hawkati's Avatar
ah - i can say a definite no to that - replaced chain recently, and is at approx 7.35......ish.
smaller numberplate? what kind of evil twisted baby eating terrorist do you take me for?!
Old 03-Aug-2009, 11:50   #6
hawkati's Avatar
eats humble pie/hat..........guilty as charged - like a complete muppet i'd hoiked it the wrong way, so was at 12o'clockish -the lowest it could possible go, and because i've been sleep riding lately i'd barely noticed.
zooped hub round the right way,and apart from number plate surviving a couple of airbournes at the weekend, it's tipping into bend sweetly now. Doh!
cheers for advice....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:54.
