Old 31-Aug-2009, 21:37
hotchillie hotchillie is offline
Bikes: 998s bostrom rep, yamaha r7, yamaha r1sp.
Mood: sustained at the mo
Cam Belt snap after 42 miles from new belts fitted
Just bought a ben Bostrom 998s with 2k miles on her, the belts had been changed 42 miles ago and the vertical belt shredded itself, thus causing damage (expensive damage) bent inlet valves, valve guides split, possible bentpiston skirt.
Hi had a interesting conversation from the doctor of dukes ducati john and he told me what had happened, the belt changer a very big ducati dealer, had loosened thebelt tensioners to adjust them, and there is a stepped washer in the back of the pully that sits inside the bearing had dropped out, they had tigtened the pully back up and sent it on its way. the problemof this is the pully then dosent sit square and the belt then tracks off line and rubs on the other pully which has sharp edges and shredded it. this was on the vertical barrel, i checked the other pullys by putting a steel rule over it and this is the same, the belt on the horizontal is shreaded to but luckily has not snapped.
The problem i have the belts were changed last year and the bike has not been used, just started up once a month and warmed up. so no come back.
Please all be warned of this. This is going to cost £600-£1000 in parts plus labour. a very expensive weekend.
Old 31-Aug-2009, 21:47
Bugger sorry to read this, I had a guy brought his bike to me with a noise after he had changed his belts, fortunately he had only adjusted the idler the wrong way so the 2 runs were just touching, so was an easy fix.
Hope you get it sorted without too much wallet heartache.
Old 31-Aug-2009, 22:24
DEMON's Avatar
DEMON DEMON is offline
Mood: on the back wheel !!
Care to let us know which duke dealer it was so we can avoid them ? you could just mention the city they are located in, thats prob enough for us to suss out who it was ...cheers
Old 31-Aug-2009, 22:34
i dont want to say yet as i want to speak to them first to see if they want to help. will update you all though.
Also need bits if any one has them. valves, piston, guides.
Chaz's Avatar
Chaz Chaz is offline
Bikes: 916 Strada
Mood: www.od2racing.co.uk
You should mention it to them they would have a record with the mileage & may do a sympathy claim or at least some decent discount! it's worth a try.
Old 31-Aug-2009, 22:52
Thanks for the warning, I will be doing the belts on my 998 in the near future so will be careful not to make that mistake
Old 01-Sep-2009, 11:29
Ray's Avatar
Ray Ray is offline
Here's the story.
http://www.ducati-john.co.uk/testast...tensioners.htm
There are a good few hints and tip on what to look out on a wide range of Ducatis on his site.
Well worth a look.
Ray.
Old 07-Sep-2009, 20:08
DEMON's Avatar
chillie
at least give us the town they are in !?
  #9
Old 09-Sep-2009, 12:24
Ray's Avatar
Ray Ray is offline
Even the best can fcuk up occasionally but how they deal with the problem is what really matters IMHO.
A hand up, yes we know we messed up and we will stand to fix it properly goes a very looooooooooong way IMHO.
Ray.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:58.
