Ducati Sporting Club
Home Calendar Gallery Membership Online Shop DSC Blogs Extras
Go Back   Ducati Sporting Club > Bike Security > Alarms and Related Security
Reload this Page Meta 357T on 996
Forum Home Register FAQ Search Forum Recent Posts Mark Forums Read
Alarms and Related Security For the discussion of Alarms, Immobilisers, Trackers, Locks, Ground Anchors and other forms of motorcycle security.
Old 02-Oct-2011, 09:04 PM
Manga Manga is offline
Bikes: Ducati 996B, Triumph Sprint ST 955i
Meta 357T on 996
This has caused me to be stranded twice.
The immobiliser 'disarmed' OK but the fuel pump would not run.
Found a thread somewhere that showed the plug/socket under the seat on LHS upper frame is ready-made to fit Ducati's own alarm. The Meta had two wires to this, so I took the plug out & shorted the socket & the fuel pump runs OK. Tested it a couple of times in & out and its definitely solved.
The bike is still immobilised until the remote is pressed, I was brave enough to go out on it today for 200+ miles and it never let me down once.
I think it is worth keeping the Meta on but does anyone have any comment on why only part of the immobiliser circuit was working?
Cheers.
Old 02-Oct-2011, 09:09 PM
Two circuit alarm
One circuit usually taps into the Fuel pump circuit and the other into the starter circuit. Each circuit is seperate and either controlled by relays or power transistors inside the alarm.
Most likely the Meta uses Relays and one of them has failed, weak electromagnetic field or carbonised contacts or faulty solder joint or alarm wiring damaged
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2019, Jelsoft Enterprises Ltd. - © Ducati Sporting Club - All times are GMT +1. The time now is 03:17 AM.
