Old 29-Dec-2011, 16:31
Stormchaser's Avatar
Stormchaser Stormchaser is offline
Bikes: ST4 & Firestorm - Sadly no more DDue Racer
Vertical Play In Swing Arm Linkages
Hi, I've just bought a beautiful ST4 which has been lovingly maintained with lots of dealer history. One thing worries me though, if I lift the rear wheel while the bike is on it's centrestand there is a couple of mil of play vertically somewhere in the swingarm or suspension linkages.
I've heard that early ST's suffered from issues with the swingarm pivot which wore unevenly and is not a simple fix, but i'm hoping it's not that since there is no sideways play.
Any ideas?
Old 29-Dec-2011, 16:36
When I build bikes the rear suspension is normally like that until I tighen all the bolts up
So I suggest checking all bolts are tight, as they may have been removed to copper-slip them
Other thing to look at is the Rod end bearings in each end of the ride height adjusting bar, they could be worn and have excessive play
Old 19-Jan-2012, 16:00
A new shock cured the same problem on my ST4, the bushes wear and they are not replaceable.
Old 21-Jan-2012, 10:38
ratchet's Avatar
ratchet ratchet is offline
Mood: bring on the sun !
Check the pivot bolt behind the frame bungs, mine has loosened several times, and that's the first sign it's slack
Old 21-Jan-2012, 11:55
Another favourite is the rear engine mount loosens up. The play comes fromt the engine rocking in the frame........
Old 03-Jun-2012, 11:59
Bornagain Bornagain is offline
Had the same problem. There are two small bushes in the top of the link shaped like top hats, on mine these were worn. Two new bushes and all sorted.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:45.
