Old 17-Jul-2004, 21:16   #1
suspension set up
good link on the 998 etc page
www.section8superbike.com
good info re the setting up of suspension!
Old 17-Jul-2004, 21:22   #2
a good direction re setting front rear sag, then phase 2, setting the forks on 4th ring and length of ride height bar to 285mm. Ive done this today, will see what its like.....
Old 17-Jul-2004, 21:29   #3
I was reading their website last night and it looks good - I like what they do with sponsorship as well, especially for track days!
Old 18-Jul-2004, 19:17   #4
Well hats off to them!! Free info that is often very hard to come by, and im impressed. It does exactly what it says on the tin, a much better feel on the front!!
Old 20-Jul-2004, 03:18   #5
chillo chillo is offline
chillo's Avatar
i checked my suspension and found i had 24 clicks of rear compression! all the setting were at least 2 to 3 clicks from supposed factory settings! my advice check them!
it handles even better now
Old 20-Jul-2004, 20:10   #6
Chillo, raise your forks through to the 4th ring. Measure the rear tie bar to 285mm. Do you sag first to 35front 30 rear. check your damping and wehey!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:52.
