Old 20-Jul-2004, 01:33   #1
Triple Nine Triple Nine is offline
Mood: Very happy with the Multi
999 Tyre Pressures?
Just been to the Bridgestone site, and they rec.
999BP
010's
Front 36PSI Rear 42PSI
Ducati rec.
Front 30PSI Rear 32PSI
How can it be so different???
Old 20-Jul-2004, 08:43   #2
dickieducati's Avatar
first is for road second track
Old 20-Jul-2004, 10:56   #3
But the lower pressures are the ones rec. by Ducati in the manual, surely that would be for the road?
Old 20-Jul-2004, 11:02   #4
you would imagine so, but they are definitely track pressures
Old 20-Jul-2004, 11:10   #5
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
The 010's work really well at 36/42.
Old 20-Jul-2004, 11:23   #6
I seem to remember another thread about this.
Was'nt 36/42psi some sort of tyre manufacturers "industry standard" pressures?
Tyreman/Mike Davis.............help!!!
Old 20-Jul-2004, 13:02   #7
superpotts superpotts is offline
always run mine (with Michelins) at32 f 36r, works fine.
steve p
Old 20-Jul-2004, 16:55   #8
Bridgestone Say
Here's the word from Bridgestone Technical Dept.
When bike manufacturers are developing a new model they have approximately 3 years during which time their test riders will be able to determine what pressures in their opinion, best suit solo and (if different) pillion riding. They are also generally only working with two tyre manufacturers who will become the original equipment (OE) suppliers. Bike manufacturers usually launch no more than three new models a year.
Bridgestone has approximately 4,000 different tyre approvals in our fitment guide so, as with all other tyre manufacturers, we obviously only have limited time to test each bike so we test for the one set of pressures that work well whether solo or with a pillion. It would be irresponsible of a tyre (or bike) manufacturer to recommend pressures that did not give optimum stability, and higher pressures lead to greater stability. If we were, due to the aforementioned time constrictions, to only recommend pressures for solo use and then a rider took a passenger along without increasing pressures, and suffered the consequent instability that may occur, it would be the tyre company that would be held to blame.
The higher pressures we recommend are perfect for commuting, touring, motorways, general riding and pillion use. The only area where you could possibly increase grip by reducing pressures is solo sport riding, and then not by a heck of a lot.
One other point - we are recommending pressures that our test riders have found best for our tyres on, in your case, a 999. Ducati have never tested BT010s on a 999 and because of the different way each type of tyre behaves, what's to say that Ducati's recommended pressures will work with our tyres?
By the way, we used a 999 as one of the bikes for our recent BT-014 launch and they suited the bike perfectly. The BT-014 is the tyre that will replace the BT-010.
Bridgestone UK Motorcycle Technical & Sales
Now where did I put that tyre pump
[Edited on 20-7-2004 by Triple Nine]
Old 20-Jul-2004, 17:00   #9
fairy nuff.
great response, pirelli supercorsa's still my tyre of choice tho.
Old 20-Jul-2004, 21:30   #10
dave w dave w is offline
dave w's Avatar
Mood: My K5 Rocks !!!!
Pirelli Diablo Corsa's...... front..33 rear...38 works for me....best rubber... ever :P
Dont last long
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:11.
