Old 29-Jul-2004, 21:22   #1
Mood: Diet
Changing front sprocket
How do you lock the front sprocket, to stop it turning, when removing the sprocket bolt.
Rob
Old 29-Jul-2004, 21:58   #2
I put it in gear and put a bar thru the rear wheel,no doubt some one will come along and tell you how to do it proper
Old 29-Jul-2004, 22:20   #3
Triple Nine Triple Nine is offline
Mood: Very happy with the Multi
Um, don't think that will stop the front sprocket from turning Karl
Old 29-Jul-2004, 22:32   #4
Mood: Diet
it would work, as the chain is still fitted.
But I think that I need a longer breaker bar, as it just doesn't seem to want to move.
Just to double check, these aren't a left hand thread ?
Rob
Old 29-Jul-2004, 22:35   #5
You can tell I'm not a mechanic can't you Rob
Old 29-Jul-2004, 23:36   #6
Mood: me in a mood? NEVER!
just knock it in gear and leave the chain on till you have it lose. and its normal thread. you wont need a longer breaker bar just shock it and it flies off.
Old 29-Jul-2004, 23:57   #7
Mood: Diet
I will have another go tomorrow with my mate there to stand on the rear brake and keep the bike stable on the paddock stand.
That will let me get a better position and use my weight. Then it should be no problem
What is the correct torque setting for this nut ?
Rob
Old 30-Jul-2004, 00:50   #8
i never torque it so cant help you there but it should say in the book.
Old 30-Jul-2004, 00:53   #9
Iv told you how to do it ....Rap a bar of some sort in a rag,place it thru the rear wheel, slap it in first gear.
Then place a scaffold bar or something over yor ratchet and hey presto :P
The jumping on the rear brake idea can end in tears
Old 30-Jul-2004, 01:09   #10
Mood: Diet
I hear you,
I already have a 2 foot breaker bar, but i think the nut may have been overtighened during PDI.
I don't have anything suitable to go through the wheel (and I am worried about marking the wheel or swinging arm)
I will try with my mate, if that does not work I will go to a friendly tyre center and get them to spin it off with a air wrench (or what every they are called)
Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:19.
