Old 02-Apr-2006, 17:46
Half man half mole's Avatar
Half man half mole Half man half mole is offline
Mood: Blue.....
High Ping Rate on New Broadband package
Just upgraded my broadband to a 10mb ntl package. I mainly use the PC for the boards and gaming (CS:S mainly).
However, when gaming my ping rate (latency) has shot up from 20-40 into the 100's. I keep getting kicked which I didn't before on the lower level of broadband. I can see no real improvement over the 2mb package, and if anything its worse with longer download times. Can anyone explain (simply) what is wrong and how the Mole can correct it? Any advice appreciated!
Have already defragged, removed unused programs, etc without any noticeable change.
Moley
PS My PC is Athlon 64 dual core, 3800 processor, 1Gb ram, 300Gb memory (with 250 available) , good Nvidia card, etc. No other programs running.
Old 02-Apr-2006, 18:29
Bionicle's Avatar
Bionicle Bionicle is offline
First check your speed http://promos.mcafee.com/speedometer/test_0150.asp be sure your gettign what you paid for, bad telephone cables can increase your ping, so can poor cables with alot of subscribers in the same area.
Old 02-Apr-2006, 18:45
Mood: Blue.....
Thanks for that link, Bionicle.
Gave the result of approx 200 KbPS. Not being too technically minded, I'm not sure what that means.............
Moley
Old 02-Apr-2006, 19:00
Totto Totto is offline
Another spped test
Visually its a bit more simple to look at
http://specials.zdnet.co.uk/misc/band-test/
Old 02-Apr-2006, 19:07
Mood: Blue.....
Strangely, this test shows my speed going off the top of the 'thermometer' - unless i've broken it!
So does that mean I need to do something to my PC to lower my latency?
All advice appreciated!
A very confused mole
Old 02-Apr-2006, 20:50
I had exactly the same problem (funnily enough in CS:S!) when my line went from 512K up to 2Mb.
I tried all sorts of stuff - dumped the QoS driver, fiddle with the MTU, other technical stuff - but it just carried on. General surfing was ok, but maxing it out when gaming just sucked.
In the end I went out and bought a new Linksys modem/router ... that fixed the problem! Turned out that the Netgear wasn't designed to work with anything more than 1/2 Mb, so it couldn't handle the higher rate.
Check the specs on your adsl box as you might have the same problem.
PS: Come and have a go at 83.142.52.155:28015 if you fancy a good pasting
Old 02-Apr-2006, 20:54
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Fwiw I upgraded to the 10Mb package and experienced slowdowns and lack of reliability - I went back down to the 2Mb package the following month - it's much better!
I forgot to add that this was with a cable package - not ADSL.
Moley
[Edited on 2-4-2006 by twpd]
Old 02-Apr-2006, 20:57
phillc phillc is offline
Bikes: 996 race bike
Mood: Almost over it.
I think there might be a problem with the speed test at McAfee. It also shows me only having 200kbps.
The ZDNet test correctly showed that I have 2Mbps (~2000kbps)
Old 02-Apr-2006, 21:03
Mood: Blue.....
Cheers Antonye - when's it get busy on that one? No players at the mo!
Out of my depth with the technical stuff - NTL fitted the box and cables, etc for me and it worked perfectly at the lower speed - its all very strange.
If you fancy giving the mole a bit of a kicking, try 85.25.2.73:27015 - dust only but fun!
Moley
Old 02-Apr-2006, 21:04
It's usually busy all the time, so dunno why there's no one on there atm!
Usually 9-10pm most nights it will be full and there's usually a good crowd on there.
I'm jumping on shortly, so might see you on there.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 21:04.
