Old 05-Mar-2012, 07:56
steeevvvooo's Avatar
steeevvvooo steeevvvooo is offline
rear master cylinder fittment - photo please
Hi all. After spending some time fiddling (with the bike) on Friday I can't figure out how to reconnect the rear brake!?
I have a new plunger as must have lost mine at Oulton, but how does it connect to the rear brake pedal? Feels like I'm missing a bit of linkage and its not pivotting right, but space is tight so I'm not so sure?
I'm using raceparts/racespares (can't remember the name but the ones everyone seems to use ) rearsets with a standard rear master cylinder so if anyone could take a photo of theirs close up I'd really appreciate it.
Steve
Old 05-Mar-2012, 09:13
its a ball ache to get it fit, its very snug as the banjo is just at the wrong angle. Plunger in first from memory, then fit the lot together....nibble fingers and patience
Old 05-Mar-2012, 09:19
Cheers. Is there some sort of ball socket/swivel which connects the plunger and the back of the rear brake lever?
I tried just slipping the end of the plunger over the pin thing that is at the rear of the brake lever but but doesn't seem to pivot properly so I think I may be missing something to connect the two together?
Old 05-Mar-2012, 09:42
Plunger should have a 6mm Rod end bearing on it, right hand thread same as on one end of a gear linkage rod
Old 05-Mar-2012, 09:49
as in, one of these...
http://image.made-in-china.com/2f0j0...al-Bearing.jpg
Old 05-Mar-2012, 09:54
A female one like these
http://www.ebay.co.uk/itm/Rod-End-Be...em256d45 e02f
Local Bearing factors should have one
Old 05-Mar-2012, 10:12
Thanks for that. I'll order one now in case I can't find one in my spares/locally as I need one asap now!
Old 07-Mar-2012, 08:09
nogaromill998's Avatar
I will have some at Brands, I keep all spares for the SES rearsets....rods, rose joints, levers, the lot.
Old 07-Mar-2012, 08:47
cheers. I have one being delivered today hopefully. I'll probably be taking tomorrow off work so if mine doesn't land on my desk today I may take you up on the offer of one at Brands.
Are you there Friday too?
Old 07-Mar-2012, 08:56
Oh yes, very early friday as i have some pads for Angry......
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2025, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:46.
