Old 27-Feb-2013, 18:27   #1
coppersaucepipe coppersaucepipe is offline
Bikes: YZF750R, DD 'B' class monster #2
Fire extinguisher testing
Where do people get it done?
Old 27-Feb-2013, 18:44   #2
dunlop0_1's Avatar
Testing in what way? If the needle is in the green then everything should be ok.
Old 27-Feb-2013, 19:48   #3
Ask at your local fire station, Tony Morley one of the volunteer fireman over at Lambourne is very helpful, he was also a full time fireman at Harwell when I was there and came around and did all the fire extinguishers in our building, I use to just sneak my race one in amongst them
Basically they will weigh them and check the pressure
Old 27-Feb-2013, 20:07   #4
So, do you mean you will be taking the DD paddocks fire extingushers home with you after Snetterton for testing then Skids
Old 27-Feb-2013, 20:39   #5
Do you get away with that? ACU rule book says its supposed to have a certificate
Old 27-Feb-2013, 20:40   #6
Thanks
Old 27-Feb-2013, 20:42   #7
Chris I said WHEN I worked at Harwell, that was 2 years ago before the Redundancy came along, this year I may just buy a new one from either LIDL or Screwfix, unless I can get hold of Tony before the second meeting which is when mine will be due.
Although I do have a couple of others that might be able to get it done for me, or maybe I could sneak it in to my new work place but not sure when they are getting theirs done
Old 27-Feb-2013, 20:47   #8
Steve Mine has a certification label on the side with about a dozen available lines for it to be signed off and dated, I'm about half way through those lines.
So the inspection is to check it conforms to the BSI referred to on the cert and has to be carried out by an approved/qualified person
Old 27-Feb-2013, 20:49   #9
£27 From Screwfix
http://www.screwfix.com/p/firechief-...bMtAodU nIAYg
Old 27-Feb-2013, 21:48   #10
I always moaned about having to pay out for a fire extinguisher, but to be honest it's one of the best pieces of safety equipment you can have either at home or in the car/van. It really could save your life or somebody else's!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:32.
