Old 27-May-2005, 20:05   #11
Agreed. But, I didn't mean to imply that the heat had to be excessive to damage iron rotors. Just repeated thermal cycling at temperatures developed during normal track and street conditions (age if you wish,) will set-up high material stresses, particularly around discontinuities like the cross-drilled vent holes. A brittle material will have a tendency to develop cracks whereas a ductile material will yield locally. So just inspect them.
BTW, don't take my comments to be derogatory, just cautionary. I think that ductile iron rotors are the single best change that you can make to improve your brakes.
Old 27-May-2005, 22:29   #12
keefer keefer is offline
keefer's Avatar
don't know what any of you are trying to imply
BUT IM SCARED
Old 27-May-2005, 22:39   #13
Felix Felix is offline
No worries, Shazaam, just a bit of anorak discussion.
Old 21-Nov-2006, 07:31   #14
Oh dear, as someone who recently fitted Brembo cast iron disks with P34 calipers I think I need to do some more checks.
I inspected the rotors completely when I installed them so am sure there were no visible cracks etc and I'm not a fast rider anyway but, I can forsee a question.
How can you visually tell the difference between sintered and non-sintered pads? I suspect the pads I have will no longer have any markings on them.
Finally - any recommendations for pads to use with iron disks anyone?
Cheers - Frank
Old 21-Nov-2006, 08:12   #15
rcgbob44's Avatar
Am I missing something?..................I cant see any picture!
Old 21-Nov-2006, 08:52   #16
I have a feeling the pic / attachment link might not have been rebuilt after moving from one server to another
Old 21-Nov-2006, 09:51   #17
rcgbob44's Avatar
Ok
I`m interested coz I fitted cast iron Brembo disks to the Jota a few years ago and that`s quite a large lump to slow down!
Old 21-Nov-2006, 10:12   #18
I guess the key points are:
1) make sure sure you ARE NOT running sintered pads.
2) inspect the rotors as frequently as possible and to change at the service limit I'd imagine
Cheers - Frank
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:43.
