Old 16-Apr-2005, 20:24   #11
psychlist's Avatar
Mood: Lucky? For some, maybe!
\"must contain a maximum of two holes 25mm dia\"
So as I see it you don't HAVE to have ANY! But how'd you drain rainwater (or oil in a catastrophe) if you din't have any?
Makes sense to have at least one at the bellypan's lowest point!
Old 16-Apr-2005, 20:32   #12
That's why I reckon its a typo and it should state "minimum" instead of "maximum".
Old 16-Apr-2005, 20:36   #13
tetol tetol is offline
Mood: ok
acu regs state maximum two holes of 25mm
Old 16-Apr-2005, 20:36   #14
I've sent a question off to demodue@ducatisportingclub.com regarding this and I'll report back the results.
Tim
Old 16-Apr-2005, 20:47   #15
As Tetol says the ACU requires that you have to 25mm holes that are plugged for dry races and open for wet races and there one heck of a lot of wet races at club meetings even when its bone dry, if the clouds are threatening rain then the wet race board goes out which means they don't have to stop and restart the race if it rains.
Normally you have one hole at the front and one at the rear to get rid of water under both acceleration and braking.
The support vans in the paddock such as A&R racing carry spare grommets for plugging 25mm holes if you happen to loose yours although I have used tank tape before now, with one end folded over on it self to form a tag, this makes it easy to remove in the collecting area if need be while holding the bike up with one hand.
Old 16-Apr-2005, 22:43   #16
DSC Member AK AK is offline
AK's Avatar
Originally posted by Ian
So whilst things like sponsor stickers are important (as without them believe me the series would not be going ahead), perhaps rules that effect safety and racing performance (ie cheating) should be the ones that get the focus at Cadwell?
Ian, I think you have missed the point here mate
nobody is on about any cheating - its clarification of DD rules, that are not quite 'per' the ACU rules we are asking for.
Straight after the agm, we had an email in February confirming a few points, also promising a full update of the rules. We havent had this yet, and its April
Whilst we appreciate all the hard work that has gone into getting the series off the ground it is now very important to get clarification - we dont have long to make any changes/additions/mods with 2 weeks to go.
Here is what we could do with being confirmed:
eg:
airbox: is this a sufficient catchcan for oil breather - as holds approx a litre, or do we need additional catchcan under the airfilter housing
mudguard - to have or not, as on monsters it is incorporated into chainguard. (acu rule 5.14 Mudguards are not compulsory)
do we have to have a top chainguard - as well as the acu sharkfin underneath (acu 5.15c)
Stickers - we have sorted ours - leaving room on forks & bellypan as suggested, so not worrying unduly about them.
Not wanting to have egg on our faces in 2 weeks time.
Alan & CK
Old 17-Apr-2005, 00:56   #17
eg:
Alan & CK
CAn't help on them all, but I've been informed by Mike (MW) that we definitely do not need to run a top chain guard or rear hugger. We obviously have to have the lower (shark's fin) chain guard though.
Tim
Old 17-Apr-2005, 09:43   #18
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
Originally posted by Rattler
The catch-tank situation is still confusing me thouugh!!!
You say that the oil breather is sorted out on a Monster (620?) by the catch tank under the seat, but what about the fuel breather? I have a pipe that exits from the back right of the tank and is fed down to just behind the engine - is this the fuel tank breather? Does this need to be fed into a catch tank? Or is this just an iverflow pipe for the fuel cap? Does the Monster use the fuel cap as a fuel breather too?
It may be obvious to some, but not to me - I must be fik !!!!
Tim
Strictly speaking that is not a fuel breather. Your fuel breather is built into the tank cap. That breath you mention serves to vent the overflow caused by overfilling the tank. This will spill over into the recess where the cap is located. It's the same as my MiniTwin racer - I don't bother routing this into a catch tank - I've had no scrutineering issues with this. You can do one of two things:
1. Remove the pipe and forget about it.
2. Route the pipe into a catch tank. Anything will do as long as it's resitant to petrol. For the non-return valve phone Alan Russell at A&R racing - he'll probably have them.
HTH.
N.
[Edited on 17-4-2005 by twpd]
Old 17-Apr-2005, 09:43   #19
cheers TW, ever since I & Mark went thru those DD rules, they have been - and seeking clarification WHY ever since, with no success
Alan
UR welcome.
Old 17-Apr-2005, 09:44   #20
Originally posted by domskidue
Originally posted by bradders
confused me when it said 4 holes in the belly pan - but that will let the oil out
I always thought it was 2 holes One at the front and one at the back of the bellypan.
That's correct. It is. The holes should be no more than 25mm in diameter.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:21.
