Old 16-Aug-2003, 19:26   #11
Mr Nick Mr Nick is offline
[Edited on 16-8-2003 by Mr Nick]
Old 02-Oct-2003, 19:50   #12
Bloody hell! I've just managed to drag myself down to RS Components and get the resistors in question. Just wired them up and hey presto - still flashing like the clappers. Removed the resistors and they are slow and steady. Bloody nuisances. I think I'll start using hand signals instead!!
Old 02-Oct-2003, 20:34   #13
Jasper Jasper is offline
Jasper's Avatar
Guy is still ahving problems with his.It might be of interest to see if the year of manufacture has anything to do with it.Mine is a 95.No problems with the resistors!
Old 03-Oct-2003, 07:06   #14
Mine is an early 2000 Biposto on a 'V'. Oh and it's yellow so do you think that could be why they are faster??
Old 03-Oct-2003, 09:15   #15
Guido's Avatar
Mine are still going like a set of sparklers on bonfire night.
Am gonna try a Ducati OEM flasher relay cos I can only guess that the Halfords unit is the chink in the armour.
Having said that…..Mr Nick’s scenario has now confused me.
I have the resistors and still it blinks like buggary. Before my relay failed, I had no resistor and the Kellermans worked fine.
2001 748R ‘51 plate
Old 03-Oct-2003, 09:18   #16
Jasper's Avatar
Guy,why not have a ride up here and we'll try mine?It is looking like a post 1999 problem-i wonder what they changed?
Old 03-Oct-2003, 09:46   #17
I had similar issues.....
.......mine flashed too fast, the I removed them, replaced them and after trying different combinations of wirings (are the indicators polarised?) I go them to work fine!!
Then one set started flashing quicker than the other side!!! I thought that this might be a loose connection, but all seemed fine!!
I've now taken them off the SPS and will be putting them on the R soon, so will try again.
Is it to do with wiring polarisation? Perhaps the front sets? Is there a wiring diagram that covers the correct wiring polarity for the indicators?
'tis a weird one and no mistake!!
Tim
Old 03-Oct-2003, 10:25   #18
Jasper's Avatar
They shouldn't be polarity concious,but who knows!!
Old 03-Oct-2003, 10:45   #19
Felix Felix is offline
I think the answer is a"heavy-duty flasher relay". They provide a constant flash rate and are not sensitive to load changes. I've used them in the past and they work well. They are a form-fit-function replacement for the OEM relay. Not sure where you get them as they don't seem to available in this country upon a cursory check. I now you can get them int he states at any auto parts store.
Have a look here:
Grote Industries
Old 03-Oct-2003, 11:34   #20
Mood: aving a laff
Mine are OK.
Got them on the rear and mirror indicators at the front so think that it balances the lower drain from the rear Kellermans?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:03.
