Old 23-May-2006, 08:03   #11
loony888 loony888 is offline
Mood: sensational!!
Originally posted by Mr. R
Hi, surely you meant 3 bar for the pump? pressure reg' is set to that as standard on strada's and 4.5 bar on sps's.
I think the pump is capable of pumping 5 bar,as fitted to these dukes.
Steve
the pump is capable but according to pete smith from epicycle you should not run pressure higher than 450kpa as the pump temperature rises to dangerously high levels. if you need more pressure than that you need a corsa pump.
Old 23-May-2006, 13:48   #12
jgriff jgriff is offline
jgriff's Avatar
The manual says 5 bar pump max before by pass operates to keep the pump cool. The pressure reg limits it to 3. Tweaking to 4.5 bar for racing with aftermarket pressure reg, although I did hear that 8 bar has been used on the track.
No matter Stefan in Germany came through with the goodies. Crisis over.
Griff
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:46.
