Old 22-May-2009, 23:29   #11
Andy748 Andy748 is offline
Bikes: Ducati MS1200 & 916 track bike
Andy748's Avatar
I have a gearing spreadsheet which may help you decide which way to go. PM me an e-mail address and I'll send you a copy.
Incidently max speed at 11 000 rpm should be 156mph on std 748 gearing, about right for track, maybe not so good for the road.
Regards,
Andy
Old 22-May-2009, 23:31   #12
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Probably 525 size and Steve's new chain is 520
The smallest renthal quick change sprocket I have in 520 is a 37T
I have a brand new 520 alloy AFAM 35T, its the type you have to fit the cush drives into
14/35 would be nigh on the same as 15/38 but without te need for the longer chain £30 to you if your interested
Hello Skids
I take it this setup would be standard ie (orignal sprocket/ crush drives)
As I did not really want to go this route unless need be.
I don't know will need to have a think
TopiToo
Old 22-May-2009, 23:34   #13
Bikes: 748ish . .
Regards,
Andy
Hello Andy 748
you have mail thankyou
TopiToo
Old 22-May-2009, 23:58   #14
steve, investing in a quick change carrier is worth it if you are buying a new sprocket anyway, cheaper and better in the long run. I had a talon carrier which was far cheaper than a renthal one and the sprockets are 325 not £145 like std!! no chnage to the cush drives
http://www.emotouk.com/ducati/chains....htm#916996998
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:02.
