Old 09-Jul-2009, 23:11   #11
you not got a wsm steve? try here http://www.carlsalter.com/motorcycle-manuals.asp
Old 09-Jul-2009, 23:29   #12
YMFB YMFB is offline
YMFB's Avatar
Thanks Paul, but I have one, however, it doesnt say which fuse or relay protects/switches the fan.
It does tell you how to test relay. Although I dont have a multimeter tonight I can get one from work tomorrow so I put 12V across terminals 85 & 86 on the two relays mounted near the fusebox on the LHS of the headlight and they both click. So unless someone can point out something else it looks like its that damned fairing off again, grrrhh.
And that folks will be any chance of me getting out again this weekend unless I very lucky as its the kids sports night tomorrow and I will be working all day Saturday so that leaves Sunday.
Just recently vehicle maintenence time is exceeding use by about 2:1, not all the Ducatis fault as much time is also being spent on the VW camper.
Old 09-Jul-2009, 23:35   #13
time for an 848 and a 1200gs mate the perfect stable
Old 09-Jul-2009, 23:37   #14
YMFB's Avatar
with my wrist as well i certainly need to think seriously about the next bike/s, having said that I really do like the ST4 it ticks all my boxes and I like the look.
Old 09-Jul-2009, 23:38   #15
YMFB's Avatar
but ive got to fix her first.
Old 14-Jul-2009, 23:08   #16
YMFB's Avatar
I have removed the LHS fairing, disconnected the fan at the big white connector and applied 12 v directly from the aux socket and the fan works, so it isnt that.
Where is the relay than switches the fan on/off located ?
Or should I be looking for a thermostat, if so whereabouts.
Either my eyesight is useless or the workshop manual assumes that the engineer knows where all this stuff is.
Old 15-Jul-2009, 00:21   #17
Rushjob Rushjob is offline
Rushjob's Avatar
Mood: :-)
Under the seat, just in front of the tool tray you wil see two relays fitted to the top of the mudguard.
The one on the right is the fuel injection relay, the one on the left the fan, that's taking left & right as if you were riding it........
Old 15-Jul-2009, 22:05   #18
YMFB's Avatar
Relays tested, fuses checked, fan checked, temp sensors tested, what next ?
I did think that I should be able to get continuity between the relay base and the fan connection but no, maybe thats the problem.
Im getting worried now, first date Snells had is 28th and MotoGP is 26th so any more help will be most appreciated.
Old 15-Jul-2009, 23:08   #19
you going 2 up to the GP?
Old 15-Jul-2009, 23:11   #20
YMFB's Avatar
thats the plan, why
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:46.
