Old 06-Aug-2009, 13:53   #11
Its currently pouring with rain and they are predicting 9mm to 12mm of rain for this evening, so I think I'll spend this evening in the garage swapping the 4-post Bucci clutch for a 6-post FBF ball and ramp clutch as Its still a nightmare to pull away on the 998R with 15/42 gearing.
I have swapped back to a standard slave and that if anything has made things worse, its attached to a Brembo Billet radial clutch lever which is exactly the same setup as on my 998Hybrid and that works fine.
The Bucci is now down to only one pair of dished plates after removing the other pair, but it still feels like the clutch only wants to be either disengaged completely or engaged, so trying to let the clutch out progressively isn't easy and I'm in danger of doing impression of Andy Sheppard on the start line at Cadwell or should that be Chris Butcher (or was he the victim in 2005)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:04.
