Old 19-Jan-2013, 09:37   #1
Spjallen Spjallen is offline
Smile Timing Belts
Looking for new belts. Oem Ducati ones seem okay price wise, but does anyone use anything different and why?
Old 19-Jan-2013, 10:31   #2
I know Andy Pike has been using others on his own bike, think he said they were the Dayco ones working out around £44 a pair
I've been using genuine ones that now cost me about £10 more for a pair
Old 19-Jan-2013, 10:35   #3
dunlop0_1's Avatar
Recently got a set for Louise's M600 £52 delivered from Ducati leeds.
Old 19-Jan-2013, 10:39   #4
Is that thr round tooth or square tooth Neil
MotoRapido are doing the square tooth belts for a 583 for £37 a pair delivered
Old 19-Jan-2013, 11:16   #5
Can you use 583 belts on a ss 620? They are much cheaper.
Old 19-Jan-2013, 12:49   #6
dunlop0_1's Avatar
Round tooth Kev. For some reason the early square ones are cheaper?
Old 19-Jan-2013, 12:51   #7
dunlop0_1's Avatar
If memory serves Simon I think the same belts fit the 620 and later 600 & 750.
Old 19-Jan-2013, 14:38   #8
Thanks Guys. Dayco are apparently are used by Ducati as oem. Going on eBay for just less than £43 pounds for two, moto Rapidio want £73 with dsc discount. If they are good enough for Andy Pike, then they are good enough for me! Standby for loads of posts on timing belt fitting!
Old 19-Jan-2013, 14:47   #9
Yep they are same width and same amount of teeth. The later belts as listed for the 620 cost about another £20 and from what I once read this is because they have a new formula in their make-up that reduces the the adhesion level between the belt and the pulley.
In some cases Ducati belts are on there third generation as they have been improved over time, but that doesn't mean you can't use earlier version apart from the Non Kevlar ones they did for the 916 etc with the white writing on them
And I would advise against using the square tooth belts on pulleys designed for belts with round teeth,
Old 20-Jan-2013, 08:26   #10
SeeleyG50 SeeleyG50 is offline
Bikes: 500 Pantah, TT2, 749R, 944ssie, Rickman Kwak 1170, Yam 1200 Super Ten
SeeleyG50's Avatar
Mood: The Older I get the Faster I Was!
Er, Kev's getting old The ones I use are Flennor, not Dayco. £32 a pair from memory. They work fine, but seem to be slightly more heavily constructed than OEM (Gates) belts. I'm certain the Dayco ones will be fine too, after all, the belts are being changed so often on the racers, that wear & ageing issues are not a factor. Just don't run them too tight.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:19.
