Old 24-Sep-2013, 11:04   #1
mbracing748 mbracing748 is offline
Bikes: Anything I can get my hands on.
mbracing748's Avatar
Class A
I hope to run in the DD series next year, as I have a national license I need to run in the Class A 618cc.
Looking at the regulations it mentions that everything about what you need to keep. My question is – because the 750ss uses the same bottom end can I change the Heads, Barrels and pistons for the 618cc, or do I need to run the 600 cases?
I’m currently building a Race 888 so I’m trying to keep the cost down for the first year. So I'm looking at different ways of obtaining a bike as there does not appear to be many Class A bikes for sale or even rent.
What I should have asked is:- Can I use a 750ss / monster Bike and downgrade to a 618cc. Looking at the regs everything can be upgrade to a 750ss spec apart from the engine CC.
Old 24-Sep-2013, 12:08   #2
You can use your 750 cases just be mindful of the oil ferrule between the cases and barrels as on my 750 cases the holes are larger than the 618.
Old 24-Sep-2013, 12:28   #3
bally71's Avatar
Mood: Inquisitive cat
I think the stroke is different
Old 24-Sep-2013, 12:38   #4
same stroke 61.5mm
620 - 80mm bore
750 - 88mm bore
750 Valves are the same size.
Old 24-Sep-2013, 19:14   #5
would it actually be cheaper to replace the heads & barrels? a used engine ain't that much.
Old 24-Sep-2013, 21:06   #6
dunlop0_1's Avatar
James Gerrard has a cracking A bike for sale.
https://www.facebook.com/photo.php?f...13 917&type=1
Old 24-Sep-2013, 22:19   #7
Hi Mike
No real problem with you using a 750 bottom end providing 620 Heads, barrels and Pistons are used, But as mentioned by Phil oil-ways etc can differ,
There are 3 varieties of 750 Cases that I know of, the old carb'd cases the first of the 750s with the clutch slave on the left and the later ones which do away with a O-ring between the cases and the barrels
I still have my spare 620 for sale at £2200
http://www.ducatisportingclub.com/sh...d.php?t=176410
The one James is advertising is another good bike I know as it's one I sold last year
Old 24-Sep-2013, 23:23   #8
Cheers guys, food for thought.
Kev, still interested but i really want a 6 speed not 5 due to my riding style.
Old 24-Sep-2013, 23:54   #9
So Mike you will also be after a 6-speed gearbox to go in a set of 750 Cases, along with the barrels, pistons and complete heads its not going to be a cheap build
Old 25-Sep-2013, 09:37   #10
Yes it may well cost me an arm and leg :-). But I do have a complete engine internals from a few bikes....
I have email James via Facebook to see if it's still for sale.
KEV - YOUR mail box is full.....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:24.
