Old 12-Oct-2009, 13:14
Chris Wood's Avatar
Question Fuel flow? Which direction around the airbox?
OK....my fuel hoses are not labeled, the base of the fuel pump is though.
My question, when looking at the airbox, which way should the fuel flow, clockwise or anti? ie. In to the vert cyl first then horizontal second?
Does it matter?
That will help me connect the right hoses.
Thanks
Confused Down Under?
Old 12-Oct-2009, 13:19
Rattler's Avatar
Rattler Rattler is offline
Mood: www.cantbearsed.co.uk
Is this the same as the water emptying counterclockwise in Aussie bath plugholes and clockwise in the UK????????????
Old 12-Oct-2009, 13:21
Chris Wood's Avatar
Wink
I hope not? wait I'll check for you.
Should I ask at my first race...'do we race clockwise or anti?'
Old 12-Oct-2009, 14:05
Originally Posted by Chris Wood
Does it matter?
Nope
Fuel is pumped out to the injectors and back to the regulator in the tank which maintains the pressure (Normally 3 bar)
Then when th injectors are triggerd the fuel is injected, as the regulator is in the tank and not mounted on the throttle bodies as some bikes are it shouldn't make a Jot of difference
Old 12-Oct-2009, 14:08
Chris Wood's Avatar
Cheers Skids.
I guessed as much.
Fuel filter is two way then?
Old 12-Oct-2009, 19:19
NO
Its on the outlet side of the pump and needs installing the right way round to get the best from it.
After the filter which exits the tank via one of the CPC couplings it doesn't matter which hose you connect as the other hose will return the fuel to the other coupling and the pressure regulator
Old 13-Oct-2009, 13:17
Chris Wood's Avatar
Talking
NO
Got it, fuel flow will always be in the right direction, either way.
Cheers Kev.
Old 13-Oct-2009, 13:19
Your welcome Chris
Now if you come across some 252Cf on your travels let us Know I need to calibrate a detector at work
Old 13-Oct-2009, 13:22
Chris Wood's Avatar
Your welcome Chris
Tried ebay?
Old 13-Oct-2009, 13:40
Tried ebay?
yep nothing comes up also tried entering Californium into the search, still comes up with Zero results
Just goes to show you can't get everything via Ebay
Although you do get a few Ebooks if you click the titles and discription box
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:27.
