Old 15-Apr-2006, 18:58
help - wi-fi!!
just bought a new laptop which is wi fi enabled, have wireless belkin router on my ntl broadband, can I get it to work...???????
I thoight these things were plug and play....anyone know a step by step giude of getting it sorted? laptop finds the router but will not connect to the internet...anyone else got a similar set up with NTL cable?
chers
Old 15-Apr-2006, 19:33
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Hello Bradders
Have you tried this http://192.168. etc which should bring up the belkin
setup/home utility, if you can get this page to load you will need to setup
some form of security, basic being 64Bit WEP. As at a guess this is your problem.
If you can not, install the disk and run through the setup again.
connecting via ethernet (yellow or Blue cabe direct to PC - modem)
ie "do not connect the router at this stage"
I have the same setup although via a desktop and Telewest, which are owned by NTL
Once you can get the above http and all is well it should say connected top right in green. then you can play around with the settings to try and get the best speeds
Hope this is of some help, I am sure the technical guys will be along
in due corse, barring that belkin have free tec support if you wanna chat to somebody in Deli.
good luck mate.
regards
TopiToo
[Edited on 15-07-1968 by TopiToo]
Old 15-Apr-2006, 20:53
YMFB's Avatar
YMFB YMFB is offline
I just spent several hours last week and yesterday trying to get a Belkin wireless router working, eventually gave up plugged in a netgear and hey presto. Thats the third one ive seen and the third one sent back.
One thing though on the belkinyou must not put http:// in front of the ip address. good luck
Old 15-Apr-2006, 21:28
Some laptops need the Wi-Fi mode turning on - I got caught out like that at Xmas :-(
Old 16-Apr-2006, 00:01
Mr_S Mr_S is offline
Paul, give me a call / text if you're still struggling and I'm sure I can find an hour to pop around.
Old 16-Apr-2006, 09:49
t5mission t5mission is offline
Mood: Will my DD fit in a Fiat Scudo?
Bradders if you still stuck send a U2U and I will send my number.
Old 16-Apr-2006, 11:55
GsxrAge's Avatar
GsxrAge GsxrAge is offline
I had the same thing with Net gear!
Dunno what was wrong I just had a mate come round and fix it
Age
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:03.
