  #11
Old 03-Jan-2005, 20:51
Glyn's Avatar
Glyn Glyn is offline
Mood: st2......we can rebuild
thats what its all about m8
great club
great peeps
great advice
  #12
Old 03-Jan-2005, 21:51
keefer's Avatar
keefer keefer is offline
isn't it nice to be able to fix something without having to pay someone £40 just to look at it.
Good work mate.
Don't get me wrong professional work shops have a time and place.
but when money is tight.
Glad we could help
  #13
Old 03-Jan-2005, 22:30
kefi kefi is offline
Mood: cheeky
Definately! Electrics always scare me so I probably would have left it till I could afford a professional. As it was it was a basic bit of detective work inspired by all your posts. Very empowering.
  #14
Old 03-Jan-2005, 22:32
Well done Kefi - no probs.
BUT !!! Please check what voltage your battery is seeing etc in case your regulator/rectifier (RR) has seen some damage.
Then let her RIP !!!
Frank
  #15
Old 03-Jan-2005, 23:00
Mood: cheeky
Thanks Frank! Is that something covered in the Haines?
  #16
Old 03-Jan-2005, 23:10
Mood: cheeky
Now I'm being lazy! I'll check my Haines Manual in the morning before I blow out some cobwebs. BTW I read somewhere that the cure for fouling plugs on the 750 was something to do with carb needles. Or is that another thread?!
Cheers you guys
Ken
  #17
Old 04-Jan-2005, 00:33
Yep - Its covered in the Haynes, needs to be able to have bike running from memory.
Plug fouling..dunno about 750 - always worth check grade of plug as there are variations between different manufactuers grades.
I had good success with a NGK Iridium plugs until one went bad
Checkin gthe needle heights is a good plan but a bit of a pain as it entails removing the airbox etc etc etc etc etc etc
Choked air filter might be a suspect as well.
Good luck
  #18
Old 04-Jan-2005, 00:58
Mood: cheeky
Thanks mate. I heard the needles go oval in time which screws the mixture... Maybe I'll start a thread but I'll search first. Going off line now...
  #19
Old 04-Jan-2005, 01:04
yep - I have heard of 'ovaling' - overhauled my 900ss carbs at 14,000 mls and the needles were fine.
Again - dunno about the 750 but the 900ss uses the same basic carb as a Y*m*h* TRX850......hint, hint.
  #20
Old 04-Jan-2005, 10:55
FiscusFish's Avatar
This
is what happens to the emulsion tubes in carbed Ducatis.
Darren
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:24.
