  #11
Old 13-May-2005, 06:49
Ducman851 Ducman851 is offline
Mood: Just Ducky
I think 6 is abit much, but coming out with them is a step in the right direction.
  #12
Old 13-May-2005, 08:48
Rob B's Avatar
Rob B Rob B is offline
Mood: I'm so happyyyyyyyyyyyy
Oh, and make sure the carbs are balanced. very noticable at low throttle openings.
  #13
Old 13-May-2005, 20:51
snagger snagger is offline
Thanx for your help all.
Just balanced the carbs last week (were ok).
I'll have a tinker with the pilot screw's, find a happy setting and rebalance carbs.
Thanx, regards Phil
  #14
Old 13-May-2005, 21:45
Get the valve clearances checked. Our M600 did the same as yours but now it starts without choke (or perhaps just a tiny bit if very cold).
  #15
Old 13-May-2005, 23:19
phil_h's Avatar
phil_h phil_h is offline
Well, I've hunted around for the carb info I used to set mine up from, but cant find it.
I'm pretty sure its 6 turns, cos the pilot screw thread is very fine, but I'll try and check mine before I go on holiday on sunday and report back (they are a ****** to get at after all !)
(Nelly and/or Louigi will know off the top of their heads I should think)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:39.
