  #31
Old 24-Jun-2005, 18:30
Green1's Avatar
Green1 Green1 is offline
Mood: 1098s...oh yes
Originally posted by Green1
I have a 14 t on the my 999, but I,ve noticed recently when I wheel the bike around it the chain sounds like aload of marbles, and I keep it oiled.
Have I over loaded it???
Any takers!!!!!
  #32
Old 24-Jun-2005, 18:33
Ducnow Ducnow is offline
Wait for mighty Shazaam
  #33
Old 24-Jun-2005, 20:50
Andy, the 996 has a standard ratio gearbox while the 999R has a close ratio, so 14/39 gearing on a 996 is equivalent to a 15/38 on a 999R.
John Hackett's matchstick analogy is good way to think about the larger bending moments in the 525 pins but chains don't fail in this manner. The most common failure mechanism is that side plate holes elongate and distort allowing the peened-over pin ends to pull away from the outer link plates. This is also the main reason why clip-type master links only have 60-70% of the strength of a machine-peened link.
The reason for the longer 525 pins is to gain a larger contact area and lower load distribution between the roller and the wider 525 sprocket face, thereby reducing the wear rate all other things being equal.
  #34
Old 24-Jun-2005, 20:53
I think tp has a 996 sps or an r??? Oh and nice shirt!
  #35
Old 24-Jun-2005, 20:55
Green1's Avatar
Shazaam any ideas on the above????
  #36
Old 24-Jun-2005, 21:00
keefer's Avatar
keefer keefer is offline
nope, bip
  #37
Old 24-Jun-2005, 21:02
I was under the illusion he had an sps or R, i think im confusing him with BDG?
  #38
Old 24-Jun-2005, 21:05
keefer's Avatar
sure he has the same engine as me.
im running 14/38 works well
  #39
Old 27-Jun-2005, 13:27
chillo's Avatar
chillo chillo is offline
i had a 525 sigma on my 998R and will putting the same on my 999R.
Keeping standard gearing as it pulls 10.5k in top easily everytime i ride it.
Change my chain and sprockets now at around 7.5k as i've had chain's fail on:
1) Fireblade RRV (14k) demolished the engine, needed replacing.
2) GSXR1000 (9k) no damage luckily.
3) 998R (8.5k) no damage luckily.
If you ride hard/wheelie/or have a lot of ft/lb to play with i wouldn't use a 520, you won't notice the reduction in gyroscopic forces etc.
Peace of mind with good chain any day
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2024, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:27.
